09-04-2016, 09:54 PM | #1 |
Rock Stacker Join Date: Dec 2004 Location: Parker, CO
| Wiring questions (need for multiple BECs)
So I am trying to understand how to setup the wiring on my rig. Currently, I have a CCBEC in driving my hitech steering servo. I want to eventually add another steering servo to the back axle, as well as some lights. The lights will come first. Do I need to add a BEC for each of these? If so where do they all plug in (all of my plugins in the current ESC are full). Sorry if this is a silly question, I am just trying to understand how all of this stuff can be added. I am looking at multiple lighting ideas, it would be nice to have a powersource "plug in" that I can use for lighting, but keep them on a separate circuit (share battery with everything else). EDIT: Also currently running a Ready Winch that plugs inline with my battery. Thanks! |
09-05-2016, 04:38 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: NW ATL
| Re: Wiring questions (need for multiple BECs)
09-05-2016, 08:10 AM | #3 |
That does help, I was trying to avoid running dual batteries for the weight added, but I guess I should consider it. I am running the 7950TH with the 10amp BEC set at 7.4 volts. I guess I could bump to a 20 amp BEC. How can I calculate the amperage at 7.4 volts? I do have a nice DVOM at home and can put it in line to get an amperage reading I guess. I will take a look at those smaller batteries. I was trying to save the second battery space/weight for a camera I am building out of a raspberry pi zero. Thanks for the tip. Sent from my SM-G900V using Tapatalk |
09-05-2016, 09:06 AM | #4 |
09-05-2016, 11:45 AM | #5 | |
| Re: Wiring questions (need for multiple BECs) Quote:
Sent from my SM-G900V using Tapatalk | |
Wiring questions (need for multiple BECs) - Similar Threads | ||||
Definitive wiring diagrams for BECs Rx Servos Motors etc. | O.C.D. | Electronics | 214 | 09-14-2018 09:30 PM |
led wiring questions | poomwah | Electronics | 24 | 03-02-2013 08:56 AM |
Several questions about wiring.... | override | Electronics | 9 | 11-10-2012 05:06 PM |
New to Crawling, have some wiring questions | eddiepfund | Newbie General | 2 | 09-23-2010 01:22 AM |
