12-13-2015, 03:14 PM | #1 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
| Rottenbellys bolt on bomber build.
Not going to be alot of fab on this rig. Mostly bolt on and go. I will build my own link out of delrin later. My bomber should be here in a few days so the prefab has begun. Electronics. Holmes Hobbies trailmaster BLE pro esc. Holmes hobbies Puller pro 540 3500kv. Castle bec. Hitec 7950 for the steering and will use the stock servo for shifting duties. Axles will be Vanquish curries with the centered rear in black. Fast eddie bearing. Vanquish VVD's. Vanquish steering bushings. Vanquish stage one kit and tierod. Gripfab lockers and OD/UD Axial gears. MIP rear yeti driveshaft for centered axle clearance. I will be using the Axial 2 speed kit. Out here there is lots of crawling and U4 racing. Trailing arms are UC fab from Dlux. Rear swaybar to be decided on still. Wheels are from Locked Up Rc. 2.2 Recluse SLW with Tarantula rings and Scale hubs. Tires are 2.2 silver compound Voodoo's with none other than Crawler Innovation foams. Got the first tire and wheels together today. Going to work on assembling the curries tomorrow. Last edited by rottenbelly; 12-13-2015 at 03:28 PM. |
12-13-2015, 04:39 PM | #2 |
Rock Stacker Join Date: Jul 2015 Location: San Jose
| Re: Rottenbellys bolt on bomber build.
Which CI foams are you using with the VooDoos?
12-13-2015, 05:07 PM | #3 |
| Re: Rottenbellys bolt on bomber build. |
12-13-2015, 05:12 PM | #4 |
| Re: Rottenbellys bolt on bomber build. Thank for the reply. I'm looking into getting a set of the VooDoos as well. I'm still in research mode as far as foams to pair with them. I'm sure they'll end up being CI foam, but still trying to wrap my head around what will be best for me.
12-13-2015, 05:15 PM | #5 |
12-14-2015, 06:18 PM | #6 |
12-14-2015, 07:41 PM | #7 |
RCC Addict Join Date: Nov 2011 Location: cold state
Feeling sick huh.... Bomber arriving tomorrow huh... Lol Looking forward to how your center axle works out for you. |
12-14-2015, 07:45 PM | #8 |
| Re: Rottenbellys bolt on bomber build. I figure if I run into clearance issues too bad I can just get the new axle tubes and offset it. But I would rather have it centered, I hope.
12-25-2015, 02:12 PM | #9 |
12-25-2015, 05:47 PM | #10 |
12-25-2015, 05:59 PM | #11 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
Are you seeing any issues with the MIP driveshaft and the centered pumpkin Currie axle? The issue seems to be the driveshaft is getting really close to the spur gear cover on the tranny at full suspension compression. I'm getting ready to buy a set of Currie axles for my upcoming Bomber build. Sent from my iPhone using Tapatalk |
12-25-2015, 06:01 PM | #12 | |
| Re: Rottenbellys bolt on bomber build. Quote:
12-25-2015, 06:03 PM | #13 |
12-25-2015, 06:24 PM | #14 |
12-25-2015, 07:16 PM | #15 |
Very nice build, love the wheels. I wish I could've kept my centered Currie but it just didn't work out. I'm running shorter Traxxas big bore shocks all around for lower COG and I was just making too much contact with compression or flex. I couldn't get my pinion angle ideal either so I ended up going with the offset rear Currie to get everything perfect. The good news is I've got an extra Currie now that gets to go on something else.
12-26-2015, 12:19 AM | #16 | |
That's what I'm afraid of. I would hate to spend the extra on a centered Currie, then find out that it's not gonna work! Then, have to spend more money to buy a set of tubes to make the centered Currie into an offset. I'm gonna run ProLine Powerstroke shocks (rear Slash) on the front and rear. From what I've researched, the ProLine Powerstrokes are a tad shorter than the stock shocks. I love the look of the centered Currie on the bomber, though!! LOL!! Sent from my iPhone using Tapatalk | |
12-26-2015, 08:11 PM | #17 |
12-26-2015, 08:27 PM | #18 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
Yup that looks great! That 1" VP light bar looks plenty bright. I might have to upgrade mine. How did you mount the rear light bar?
12-26-2015, 09:00 PM | #19 |
| Re: Rottenbellys bolt on bomber build. It's the yeti rear bar. I cut the back lip off the roof. Then I drilled 2 holes where the stock rear roof holes are for mounting.
12-27-2015, 09:59 AM | #20 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
I am getting my Bomber back together after adding the SSD 2 speed. Hom much affect do you think the 2 speed has on the low end for crawling? Outstanding build on your Bomber. I hope mine will be as impressive. Thanks for sharing.
Rottenbellys bolt on bomber build. - Similar Threads | ||||
Rottenbellys BWD Wedge XR build. | rottenbelly | Axial XR10 | 71 | 08-09-2012 11:07 PM |
Rottenbellys BWD Wedge build. | rottenbelly | EnRoute Berg | 47 | 10-19-2010 06:27 AM |
Rottenbellys super build!! | rottenbelly | Superclass Crawlers | 33 | 06-22-2010 07:00 PM |
Rottenbellys DNA WK pro comp build. | rottenbelly | HPI Wheely King | 130 | 03-17-2010 05:14 PM |
Rottenbellys RJ funny car build. | rottenbelly | Non Crawler RC's | 39 | 09-14-2009 07:25 PM |
