11-30-2016, 03:57 PM | #1 |
Newbie Join Date: May 2016 Location: Boiling Springs
| Stiffer springs needed. powerstrokes.
I got the proline powerstrokes and am using the max springs in the rear which are red. 6lb/in. I need stiffer springs. I was just gonna buy 2 more shocks, but the trailing arms I have are the wraith blue monkeys that only have the 3 holes for mounting shocks. The yeti/bomber arms have 4 hokes. So if I where to add 2 rear shocks, they would touch. Does anyone know of other brands of springs that have greater rates than 6lb/in?
11-30-2016, 04:44 PM | #2 |
Quarry Creeper Join Date: Jul 2013 Location: PA
| Re: Stiffer springs needed. powerstrokes.
Are your current shocks setup in the most rearward postion on the TA? How heavy is your Bomber? I tested some Losi eight T springs on powerstrokes xt's I got them to fit... if your running XT's shoot me a PM, I have a bunch of spare springs up to 12lbs you are welcome to try...
11-30-2016, 06:10 PM | #3 |
My bomber is 11+lbs. Im running the slash powerstrokes rear. They are 55mm long. If I add the second shorter spring on top the combined lenght is close to 3". What lenght are those losi springs?
Tags |
greater, powerstroke, spring rate |
Stiffer springs needed. powerstrokes. - Similar Threads | ||||
Stiffer Springs | chino | Axial SCX-10 | 4 | 02-26-2015 11:00 AM |
SHOCK TUNING per-load vs stiffer springs | johncraddock445 | General Crawlers | 8 | 01-25-2015 10:54 AM |
Help with suspension: stiffer springs needed on custom build | cragv | 1.9 Scale Rigs | 4 | 07-25-2014 03:30 PM |
Need Much Stiffer Springs for Trail Trekker Mod | rampa202 | Losi Micro-Rock Crawler | 11 | 04-28-2012 07:01 PM |
Stiffer high lift internal springs? | 1BadJeepBruiser | General Scale Talk | 15 | 04-11-2007 07:48 PM |
