06-03-2018, 07:36 AM | #41 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Greatscott's RR10 Quote:
Sent from my Nexus 6 using Tapatalk | |
06-03-2018, 11:05 AM | #42 | |
RR10 by GreatScott, on Flickr RR10 by GreatScott, on Flickr | |
06-03-2018, 11:10 AM | #43 |
Quarry Creeper Join Date: Jul 2017 Location: Sweden
Thanks! Added to the wishlist. Odd that you have to buy them as an upgrade, considering how cheap they are.
06-03-2018, 11:21 AM | #44 |
They also come stock on the wraith... Sent from my Nexus 6 using Tapatalk |
06-25-2018, 08:42 PM | #45 |
Just upgraded to aluminum panels. They are Integy, but they were a good price and fit well. Untitled by Scott O, on Flickr Untitled by Scott O, on Flickr For some reason the paint did not adhere to the panels that came in the kit, I obviously screwed something up, just don't know what. I have painted up my fair share of laxan bodies, did all of the normal stuff, I have never had a paint job flake up like this before. The big spot on the left is where the paint of off of the laxan showing a big air bubble between the paint and plasatic. Untitled by Scott O, on Flickr Every place that is a lighter grey is where the paint is off of the lexan. Untitled by Scott O, on Flickr |
08-25-2018, 02:24 PM | #46 |
So, I have come to realize that running full-size 3S packs in this thing sucks (4300mha). The run time is great, but getting them in and out is a pain. So, I was thinking of running 3S 2000mha (ish) packs. Granted these packs are not all that expenisive, but before I buy a few of them I wanted to know if anyone else ran packs like this, and about how much run time to expect (Mamba X with a 1900kv sensored motor).
08-25-2018, 05:07 PM | #47 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
I've been running Floureon 2800 3s packs in mine. They fit very easily, even more important since I just changed to a balance plug powered servo. Combo trail/crawling I've been getting right at 2:45 - 3:00 hours run time.
07-18-2020, 09:33 PM | #48 |
I am having a bit of annoyance with this rig. The drag brake sucks, really sucks! I am running a Mamba-X with an 1800kv motor on 3S. This combo on both my TRX4 and TRX6 are wonderful, there is a little bit of slippage on the steepest of grades, but that is it. In the Bomber, there is some resistance, but even on small inclines it rolls. I have gone through and checked all of my settings, everything is as it should be. I know the portals help the TRXs a bit, but the Bomber is miles away from either of these rigs. Any suggestions? |
07-19-2020, 11:23 AM | #49 |
You could always gear it lower to increase the motors advantage over the wheels (and therefore, holding power) if you're willing to give up some on the top end. If you don't want to lose top end speed, switching to a higher kv motor and gearing down is an even better option with really no negative trade offs (except having to buy another motor!) I don't know if increasing voltage (as in: running 4s) would also increase it's holding power, but it would certainly allow you to run lower gearing without losing top speed. With that low of a kv, I wouldn't even flinch at feeding it 4s, or even 6s for that matter, you've already got multiple small 3s batteries that could be run in series to experiment with this. Other than that, weight loss would be where I'd look next.
Greatscott's RR10 - Similar Threads | ||||
Greatscott's Rubicon Build | Greatscott | Axial SCX-10 | 24 | 05-10-2021 08:09 PM |
GreatScott's TF2 Reboot | Greatscott | RC4WD Trail Finder 2 | 74 | 07-30-2018 05:55 AM |
Greatscott's TRX4 | Greatscott | Traxxas TRX-4 | 17 | 07-14-2018 11:20 PM |
Greatscott's M2 XR-10 | Greatscott | Axial XR10 | 94 | 01-27-2015 11:55 AM |
Greatscott's SWX (Finished at last!!!) | Greatscott | Axial AX-10 Scorpion | 7 | 03-08-2010 11:02 PM |
