02-15-2012, 01:35 PM | #1 |
Quarry Creeper Join Date: Apr 2011 Location: Mid TN
| adding weight on scx10
How much weight do you all add to a set of aluminum wheels on a honcho?
02-15-2012, 01:41 PM | #2 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: adding weight on scx10
Hey, Craig. My total wheel / tire combo weighs in around 8.0 oz. That is running DarkSoul beadlocks with 24 pin weights, RC4WD Baja Claws TTC with the foams that came with the tire. I think with RC4WD Rok Lox it was around 7.4 oz with the same wheel set-up. Hope that helps. |
02-15-2012, 01:57 PM | #3 |
Thanks, I got some stick on wheel weights im going to add.
02-15-2012, 02:03 PM | #4 |
My rc4wd wheels weight 2.0oz each
02-16-2012, 01:09 AM | #5 |
Pebble Pounder Join Date: Sep 2009 Location: joppa,al
thats like asking wich is better, chevy, ford, dodge etc... everybody says something different and actually everybody is right, because that's what they like, not the other people. the key is to drive it and see what you like it to be around. start light and keep adding till you find the point where you go " man this thing handles so much better since i put ___________(insert amount of weight here) oz's in the rim's"! a good start may be 4 oz's in the front, have fun and good luck!
adding weight on scx10 - Similar Threads | ||||
Adding weight??? | BigMack | Losi Mini-Rock Crawler | 5 | 11-21-2011 03:02 AM |
adding weight | Briguy-01 | Team Losi Comp Crawler | 11 | 12-28-2009 02:43 PM |
Adding weight | Drey | Newbie General | 13 | 03-24-2009 04:12 PM |
Adding Weight | 93yj6044 | General Crawlers | 11 | 05-23-2006 07:42 AM |
Adding Weight to Axles | Turboduck01 | General Crawlers | 8 | 10-01-2005 07:37 AM |
