03-06-2012, 05:25 PM | #1 |
Rock Stacker Join Date: Mar 2009 Location: Tacoma
| SCX10 is lacking something-need advice
I have an SCX10 TR kit. Shortened WB to fit JK body. My issue is that I feel its lacking some top end. Its either gearing or motor but I feel it should have more. Here's what I got. Older Tekin 35T machine wound motor and Tekin FXR. Battery is 3S 4000mah. Gearing is 14t pinion and 87t spur. Speed on 2S is 4mph Speed on 3S is 6.2mph at best. Seems to have good torque. I want to crawl as well as have some hop to it. Weight of vehicle is 6 LBS. I have solid Aluminum Wheels and sticky weights weights on front and rear battery holders. I want to go 4S but if I'm only to gain another 2mph its not worth the $170 I would spend to be able to do that. Should I be running another motor or a different gearing combo? What your thoughts on my overall set up? http://youtube.be/MBpyKFWz5FA |
03-06-2012, 05:41 PM | #2 |
Quarry Creeper Join Date: Jul 2009 Location: Back from vacation!!!
| Re: SCX10 is lacking something-need advice
Have you tried a 20t pinion??? That will step it up some.
03-06-2012, 08:15 PM | #3 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
| Re: SCX10 is lacking something-need advice |
03-06-2012, 08:18 PM | #4 |
Newbie Join Date: Jan 2012 Location: Lake Of The Pines
Take out all of the weight for starters and try it. Mitch |
03-06-2012, 08:31 PM | #5 |
Pebble Pounder Join Date: Mar 2011 Location: St. Louis
At least take the weight out of the rear and try it.
03-06-2012, 08:51 PM | #6 |
10-4 on the weight. It's looks a little hefty.......
03-06-2012, 09:56 PM | #7 |
Pebble Pounder Join Date: Sep 2010 Location: Lees Summit
I'm running basically the same and feel the same way. I have a brood machine wound 35T and a Mamba Max, but with the 14t pinion it is on the slow side on 3S... I am thinking i'll gear up a little, but hate to go all the way to 20t. I have a 15t pinion, but might get a 17t or so to try. I'm running plastic wheels and have no extra weight. |
SCX10 is lacking something-need advice - Similar Threads | ||||
6x6 Lacking power | rcmaniac24 | Electronics | 8 | 05-03-2010 07:42 PM |
Customer service is lacking these days. | boisetrucker | Chit Chat | 23 | 01-01-2010 01:53 PM |
Scx10 Advice! | Veilside159 | Axial SCX-10 | 5 | 12-04-2009 05:22 PM |
45T lacking power? | GraTou | Electronics | 15 | 12-16-2006 04:12 PM |
lacking a remote | muddeprived | General Crawlers | 7 | 01-09-2006 03:35 PM |
