Thread: Troubleshoot.
Old 06-22-2012, 06:49 PM   #1
Default Troubleshoot.
A friends scx has a problem. He is running 2500mah 3s. Transmitter turns on, truck turns on but ESC doesn't chime or make any sound. Steering works, motor doesn't. All connections checked.
Any ideas?
Soulo747 is offline   Reply With Quote
Old 06-22-2012, 08:21 PM   #2
Default Re: Troubleshoot.
Your battery died
In all seriousness I could only think maybe a trottle trim, etc got bumped? I know some esc's won't start up if it doesn't see the signal in the correct range that was programmed When doing the esc setup. Kind of a protection so it doesn't take off on you when you turn it on. What type of electronics are they?
Rook82 is offline   Reply With Quote
Old 06-22-2012, 09:03 PM   #3
Stock electronics.
Old 06-22-2012, 09:11 PM   #4
Did you try switching the channels around to see if you can still get steering by using the throttle?
Mr.Joshua is offline   Reply With Quote
Old 06-22-2012, 09:14 PM   #5
Check the connections at the motor. The ESC needs a motor hooked up to actually hear a "chime", so if the connections are iffy, you won't hear anything.
Solitaire is offline   Reply With Quote
Old 06-22-2012, 09:53 PM   #6
Thanks guys. Motor wires are snug. Not sure about the throttle channel, I'm no longer with the dude. I don't think he's fixed it yet though.
Old 06-22-2012, 10:07 PM   #7
I have not. I'll try the switching the steering.
Caaba is offline   Reply With Quote
Old 06-22-2012, 10:32 PM   #8
Thanks everyone. The connection to the motor was sliced, couldnt see it until I pulled on them. It's running fine now.
Old 06-22-2012, 11:07 PM   #9
Nice call solitaire
Troubleshoot. - Similar Threads
Holmes Hobbies Motor Troubleshoot ModTrialsRider Electronics 10 01-18-2012 11:43 PM
BEC Troubleshoot Harvo Electronics 8 03-01-2010 11:31 PM
Triton EQ Charger Troubleshoot Question Offroader5 Electronics 6 06-16-2009 09:22 PM
BEC Mamba troubleshoot Desert Rc General Crawlers 2 03-01-2009 02:40 PM
