Thread: first scaler, relocated electronics...
Old 09-09-2012, 06:38 PM   #1
Default first scaler, relocated electronics...
so this is my first scx10 i pickd up a few days ago. so far, i love it! last few days ive been running the piss out of it and also doing free/cheap upgrades to it.
first thing i did was tore down both axles and cleaned them and added in some marine grease.
open the trans and did the same thing.
plasti dip the esc
mirror/flip the motor/trans
and now i moved all the electronics back and lowerd the battery
i know everybody likes everything up front, but i hated the messy look.
my next mods will be a dx3 remote, new steering servo, then new shocks and the A mount for the rear shocks.
bobd80toy is offline   Reply With Quote
Old 09-09-2012, 07:28 PM   #2
Default Re: first scaler, relocated electronics...
Lookin good man! Is it goin to be a muddin rig!
mitchr97 is offline   Reply With Quote
Old 09-09-2012, 07:38 PM   #3
being up in the NW in the seattle area, of course! it'll be an all around 4x4, mud, rocks, water, etc.
ill water proof the the steering servo and reciever once i get the new ones
Old 09-09-2012, 08:10 PM   #4
AddictedtoRC1's Avatar
Looks good. I run my electronics in the rear also. The receiver box is behind my shock hoops like a gas tank and my ESC and BEC sit on the cross member. I don't have any issues with weight at all.
AddictedtoRC1 is offline   Reply With Quote
Old 09-09-2012, 11:17 PM   #5
I would recommend getting either a spur gear cover or maybe zip-tie to keep wires away from the spur gear. Kinda asking for trouble with the wires straddling the tranny like that - can suck that loose wire right through if you hit a bump. Otherwise looks good!
Perkolator is offline   Reply With Quote
Old 09-10-2012, 08:04 AM   #6
yea i know. i tried to get some of the wire holders that come on the truck but you got to buy a hole dang kit that cost almost $20. ill defintely get somehthing tho
Old 09-10-2012, 08:20 AM   #7
I joined the Band!
I did the same thing with my electronics... didnt want the antenna coming up through the windshield or anything, looks much better coming out of the rear. As far as wires in the gears... I agree, mine has a shield of sorts. I used the front part of an old RC10T chassis that makes a bend upward and bolted it to the rear cross members. This gave me a nice flat spot to velcro my radiobox and helps keep the wires out of the gears.
Check my mini-build thread for pics...
My Honcho/Dingo/Chevy... (updated 7/27)
devestator_x is offline   Reply With Quote
first scaler, relocated electronics... - Similar Threads
How-to relocated your Servo on the C-frame: SwampDawg Axial SCX-10 25 08-08-2013 12:40 PM
Receiver box relocated to rear? Help please... MLambert19 Axial SCX-10 4 01-15-2012 05:08 AM
Relocated my shocks! airranger Tamiya Txt-1 and Juggernaut 32 10-29-2004 09:54 PM
Relocated shocks on my TXT badger Tamiya Txt-1 and Juggernaut 35 09-10-2004 05:20 PM
Steering servo relocated to the other side of the axle schlabinski Tamiya Txt-1 and Juggernaut 4 03-13-2004 11:20 AM
