09-12-2012, 08:41 AM | #1 |
Newbie Join Date: Sep 2012 Location: 413
| locked diff?
Are the stock axles on the scx10 locked, open, or lsd?
09-12-2012, 08:48 AM | #2 |
| Re: locked diff?
I believe all the kits and rtr now come with locked diffs. The old Scorpion Ready To Race had an open front diff. |
09-12-2012, 08:56 AM | #3 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| Re: locked diff?
Welcome to the forum. You can learn a lot from RCC. A few seconds of searching results in the information below direct from Axial's website... AXLES - PROVEN DURABILITY The axles have been designed with many features that are not available from other products on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration when designing these axles. The result is a far superior axle that will stand up to some severe punishment. To ensure added longevity from the start a hi-tolerance sintered diff locker is included along with hardened axle shafts. HEAVY DUTY DIFFERENTIAL LOCKER Made from strong sintered metal. Sintered metal provides superior metallurgical characteristics and can be manufactured with very tight tolerances. Adds weight where it is needed in the axle. Simple one piece design. Reduces slop in drivetrain by eliminating cross pin. PROVEN DURABILITY - AXLES DESIGNED WITH PERFORMANCE AND DURABILITY IN MIND The axles have been designed with many features that are not available from other products on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration when designing these axles. The result is a far superior axle that will stand-up to some severe punishment. To ensure added longevity from the start, a high-tolerance sintered diff locker is included along with hardened steel axle shafts. __________________________________________________ _____________ That one is free. SEARCH!!! |
09-12-2012, 09:34 AM | #4 |
| Re: locked diff?
So if everyone always searches and doesn't discuss or ask questions then all we have is a dictionary/manual and not a forum. Thanks for the info. |
09-12-2012, 11:29 AM | #5 | |
| Re: locked diff? Quote:
Posts like your original one, lead people to think you are upping your post count. Join date SEP2012, low post count, single question that is easy to find answer, what would you think? You did good in your thread (newb needs help to get my crawler going again) where you asked for help about your smoked motor. You gave your set-up, brief description of your problem and what you were looking for in your question. Do you have a specific problem that involves the locked axles? | |
09-12-2012, 01:38 PM | #6 |
| Re: locked diff?
Yes I feel like they r slipping at times almost like a LSD. I am not trying to up my post count just trying to get a quick answer that I know would be way for someone to answer that knows. I would of actually paid to be a supporting member if I didn't get so much hassle for my posts. The way this site is run I don't really want to be a supporting member. You seem to outcast all new members until they "prove" them selfs. |
09-12-2012, 01:57 PM | #7 | |
I joined the Band! Join Date: May 2009 Location: Palm Bay
I would think he's a new user that was looking for a quick and simple answer. Sometimes larger discussions can stem from a simple small question. The only stupid questions are the ones that arent asked. | |
09-12-2012, 02:14 PM | #8 |
Quarry Creeper Join Date: Dec 2010 Location: Alberta
| Re: locked diff?
Do the stock axial tires come with foams? Errrrrrrrrr...
09-12-2012, 02:35 PM | #9 | |
| Re: locked diff? I respectfully disagree. Have you had the axles apart for inspection? Could be the stock ring & pinion wearing and slipping. Could be the locker has worn and has rounded. I would guess the ring & pinion is bad, or going bad. Does it 'click' or 'pop' and slip if you hold a tire and press the throttle? Give a for instance where the issue has presented itself. Quote:
I think you get the point I am trying to make. So, lets move past this 'posting a question' issue and get to solving your true problem with your axles. | |
09-12-2012, 02:45 PM | #10 |
| Re: locked diff? I'll bet it's the locker, not the gears. Is just one wheel slipping or both? Like btoungette said, try holding the wheel that you think is slipping and see if you can make it slip... or just open up the axle and know for sure. heeeeeeeeey, I tried to help you w/o any hassle. |
09-12-2012, 02:45 PM | #11 |
| Re: locked diff? Post like this on r the ones you should be concerned with. Absolute no reason to post this but nothing is said to people like this. As far as I am concerned you can lock or delete this thread seeing how my original question that didn't need to be asked in the first place has been answered. |
09-12-2012, 02:52 PM | #12 |
| Re: locked diff? I know your original question has been answered, but what about the problem that made you ask your original question? Are you just going to let it "slip"?
09-12-2012, 04:19 PM | #13 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| Re: locked diff?
Yupp... both front and back are locked... but they are very sloppy
09-12-2012, 04:36 PM | #14 | |
Anyhow onto my question... Is that stock slop in the locker something to be concerned with? Could that eventually lead to premature wearing of axles or even the ring gear? | |
09-12-2012, 04:43 PM | #15 | |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
I like this response . No offence to the person I think it was directed to. But as people are here for some time, they will get to know how things go and stumble across more information. Not everyone starts off knowing how to search in a way that gives them good results. Yes the information on how to do it is out there...but you have to search for it . Honestly hearing people say "search" is imho way more annoying then people asking questions that have been asked before. Don't take things so serious, you will not stop the inevitable repeat of questions. I don't think I have ever told someone to search on here and I have been here for years. If I see something that is a re post of questions, I just read it without response or move on. Why the need to feel like it is "your" responsibility to school people on forum use? Scutt, Your slipping experience could be a few things. The axles are locked as others have said. But there are a few things that could cause that sensation. One is lose set screws on the driveshafts. They have been known to come lose even with liberal use of threadlock. Under a high stress or bind situation, they may slip on the axle pinion. The motor and shafts will be turning but the wheels will not. Now obviously this would effect both wheels on the given axle. But it is a possible place of slippage. Another is there is a slipper clutch on most models of SCX10's. if this slips then all tires will not move. I do not know how much experience you have with these or rc's in general. Those are both basic things and common on rc's. But if you didn't know about them then it could be frustrating not knowing how to deal with those issues. If you have one tire on an axle that is not spinning at times then it could be a few things. Wheel mounting nut not tight enough (would be pretty obvious and doubtful, but I have seen it happen). Stripped wheel hex. If plastic wheels, the hex area can strip out and the hex that the wheel bolts onto will spin in the wheel. I have had this happen on many sets of SCX wheels. Usually only happens when you up the power over stock and run larger tires. Those are the main things I would check and check as normal maintenance (hex's, set screws, oil the bearings, clean crud from driveshafts, tighten all screws,etc). Be carefull when checking or tightening the screws that hold the transmission to the trans skid. They strip very easy. Good luck! | |
09-12-2012, 04:53 PM | #16 | |
The trans should have a locked gear output with "no" play. Some versions use aluminum out drives bolted to the gear in the trans. Some have steel (must stronger). There are aftermarket options for a one piece gear with out drives in steel or other hardened metal. Very worthwhile imho. I ruined a few sets on my first scx's. Now when building one, I don't even bother with stock and go right to the steel on that part. I would take the trans apart to see what is the deal. First I would check to make sure the drive shafts are not slipping on the trans out drives. Over time the setscrews can hog out the out drive on the aluminum versions and allow play. If it is the gear inside, I would replace it with either steel outdrives or a one piece gear and outdrive. one piece outdrive and gear: Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 steel outdrives: Axial Replacement Steel Outdrives for the Axial Transmission I have used the steel out drives (second option) on three of my SCX's. The other I have a version of the first link made by "Hot Racing". I have never had an issue with the gear itself, only the out drives. The steel out drives have been great on all rigs. I know some people have issues with the gears in the trans, but I have never had a failure on any of my rigs. Only the aluminum out drives have failed and they failed on every rig they were on. | |
09-12-2012, 08:48 PM | #17 |
| Re: locked diff?
Sorry Rook... I should have been more specific... My question was directed more towards the play in the axle diff. I know the trans shouldnt have any play. My issue was caused by the grub screw being slightly loose and wearing the output shaft into a nice round pin. I have since replaced everything with a Wraith trans and through pins rather than grubs. But yeah can that play in the locked axle diff cause any issues in the long term? |
09-12-2012, 09:38 PM | #18 |
| Re: locked diff?
Depends on torque being applied, in some situations I'd say don't worry about it and in others it'd be a good thing to upgrade. An integy lathe motor on 3s won't do much damage in that dept, a tekin pro4 on just 2s on the other hand... These are a step up and work well: Hot Racing Unibody SHD Differential Locker AX10 SCX10 Wraith #SCP125R *-*Driveline Parts: Axles and axle parts*-*-By Truck: Axial AX10 Scorpion, SCX10, Honcho*-*The Crawlers Store LLC |
07-08-2013, 05:14 PM | #19 |
Newbie Join Date: Mar 2013 Location: Dietrichville
| Re: locked diff?
wanted to upgrade my axles from stock locker to either Robinson Racing Outdrive Diff Lock Gear AX10/SCX10 or Hot Racing Axial SCX10 AX10 Wraith Unibody SHD Differential Locker anyone have either these with any comments
07-08-2013, 06:22 PM | #20 |
Quarry Creeper Join Date: Jul 2009 Location: Dublin,Ireland-Cluj,Romania
| Re: locked diff?
robinson products are bulletproof,so go on with them.as far as HR.....I had bad experience with them,and since then,i am staying out of there products
locked diff? - Similar Threads | ||||
has anyone locked the diff in their slash? | dieselfuel | Non Crawler RC's | 15 | 10-14-2008 09:36 PM |
locked diff poll | Rockpiledriver | Tamiya TLT Crawlers | 23 | 06-07-2006 05:12 PM |
locked diff | tltcrawl | Tamiya TLT Crawlers | 15 | 09-05-2004 12:22 PM |
i just locked my juggernaut diff a new way | austinsclod | General Crawlers | 1 | 07-08-2004 04:12 PM |
Locked the rear diff... | XFACTOR | General Crawlers | 9 | 07-07-2004 09:02 AM |
