Thread: Southern SXC10 Build
Old 01-09-2013, 02:18 PM   #21
Default Re: Southern SXC10 Build
+2 on the Fusion paint. Love those axles!
The DC is offline   Reply With Quote
Old 01-09-2013, 02:27 PM   #22
Originally Posted by TNT1 View Post
Krylon Fusion paint.
Thats what I used for Kramer The Tundra.
jthellfire911 is offline   Reply With Quote
Old 01-12-2013, 05:45 PM   #23
Took advantage of my day off to get some new goodies installed. Making steady progress on my build. I'm addicted to scalers!
Got my VP High Steer Knuckles installed. Also got all of the Ti Linkage from VP as well.
GravelDuster is offline   Reply With Quote
Old 01-12-2013, 05:46 PM   #24
New Shoes!! Thanks to LockedUpRc and Proline.
Old 01-12-2013, 05:52 PM   #25
Body Finally arrived too, man, its cooler than I thought. This will be my first hard body, so I'm going to take it slow. Picked up some primer and some color coat. Going with a rootbeer color with some very slight metal flake in it. I think its going to look sick. Also got the super cool pack of sand paper at hobby lobby. It is a Professional Modeler Pack, it has 320, 400, 600, 1000, 2000, 4000, 6000, and 12000 grit. I didn't know it went that fine. I have a lot of body prep ahead of me.
Old 01-19-2013, 08:27 PM   #26
After much head scratching on how to mount to body, I had an idea. I took some of the stock body mounts and cut the nipple off the end.
Then I snatched up some industrial magnets form work and attached them to the posts.
Got everything installed, I think its going to work, these 4 (two on the posts, two on the inside of the body) will easily support the weight of the truck, it take about 10 lbs. to separate one set. Also took advantage of the break in the rain to get my primer coat laid down. Getting close.
Old 01-19-2013, 08:46 PM   #27
love the build!
That sandpaper... sheesh what are modelers sanding @ hobby lobby? primer stops at 600 -1000 grit (the finer for the metal flake- deep scratches from coarse sandpaper will mess with the flake) all the rest are for color sanding and for doing things like refinishing headlights and clear plastic.
4starCstms is offline   Reply With Quote
Old 01-20-2013, 10:10 AM   #28
Thanks guys, The hard body is a huge pain in the ass, got 3 coats of primer on it and all wet sanded. Now that I look at it I may not even color coat it.
Old 01-27-2013, 08:41 PM   #29
Got some more work done. My VP OMF bead locks came in, got those paired up with some LockedUp Rings and TSL Swampers. I scratched the root beer idea for the paint and went with a satin black. Color coat is down, just need to dull coat it. I'm staying away from clear coat, I wanna keep it flat. Starting to look damn good.
Old 01-28-2013, 08:50 AM   #30
What do you guys use to mock up a cage? I need something easy to bend so I can get a good idea of what I want for the rear.
Old 01-28-2013, 09:31 AM   #31
you can use brass rod. it bends easy and is pretty cheep
villainous is offline   Reply With Quote
Old 01-28-2013, 08:53 PM   #32
Thanks man, and here very shortly it will be cut in half...really...the chassis is getting chopped at the cab. So sad.
Southern SXC10 Build - Similar Threads
Vanquish SCX10 Currie Axles IN Stock RPP Hobby RPP Hobby 2 03-26-2015 07:54 PM
VP Currie Rear Axle Assembly PrjktRedRubi Axial SCX-10 7 12-27-2012 06:20 PM
New Vaquish Axles - Thank you Currie bigstu General Scale Talk 60 12-11-2012 06:04 AM
crawlin with currie peyton. Axial AX-10 Scorpion 14 07-05-2009 11:31 AM
