Thread: Front Link setup
Old 03-06-2013, 08:37 AM   #1
Default Front Link setup
Hey I just got a Honcho. Old to RC, new to trail rigs. I was looking at the link setup tonight and I'm confused. The rear has a "4link" setup. Why is the front using the Y link, "3 link" I think it's called? It comes with another 4link truss in the parts bag, but it doesn't have the post for the servo pad on it like the 3link truss does. As well there is 2 links in the part bag. I'm sure the 4link truss could be easily modified to have a post to support the servo pad. Do people do this? Why does it come with Y link in front? More scale look? If it gives better movement in the rear, wouldn't it do the same in the front? I've been doing lots of research on the SCX10 on forums and never heard once anyone mention the 3link in the front and swapping it for the 4link. So I'm assuming people don't and wonder why.
Sapes is offline   Reply With Quote
Old 03-06-2013, 09:04 AM   #2
Default Re: Front Link setup
Who knows.The Y-link basically is a 4 link with a shared connection point at the axle. Both the 4-link and Y-link provide the same exact function of clocking and locking the axle side to side in conjunction with the bottom links. My main reason for swapping was because I don't like the slop of the Y-link connection. My servo plate has been fine without the 3rd screw.
05Fronty4x is offline   Reply With Quote
Old 03-06-2013, 10:05 AM   #3
I tried the 4 link front with the stock parts and just mounting the plate with 2 screws. It worked fine I until I went to a hitec 7950 servo and 2.2s. It flexed a lot and the screws pulled out. I bought a 4 link servo plate for $20 and haven't had a problem since.
xCoolHandLukex is offline   Reply With Quote
Old 03-06-2013, 01:03 PM   #4
K thanks guys.
Front Link setup - Similar Threads
4 link front setup - missing bolt? igz Axial SCX-10 14 01-22-2013 12:42 PM
Link setup on TCS 4 link plates and boulder chassis sdcrawls Axial AX-10 Scorpion 8 11-17-2009 02:37 AM
Is my setup right? CKRC Stage 2 setup - front axle castor Miller Time Axial AX-10 Scorpion 14 03-01-2008 12:54 PM
IFS w/ 4 link front and 3 or 4 link rear. T-Man Traxxas Crawlers 6 10-26-2004 07:28 AM
