03-17-2013, 08:07 PM | #1 |
Rock Crawler Join Date: Jul 2011 Location: palm desert (southern cali)
| rubicon kit
question im thinking bout getting one but i wanna know if it comes with what you need to four link the front im used to the old honcho with 4 link rear CMS front but im gonna try servo on axle this time
03-17-2013, 08:24 PM | #2 |
RCC Addict Join Date: May 2012 Location: The Volunteer State
| Re: rubicon kit
the manual tells you to 3 link the front and 4 link the rear, but in the parts bags there is a spare 4 link truss and plastic links to do the front. As with most Axial kits only the lower links and steering are aluminum and now the Icon shocks in this kit. Hope that helps some
03-17-2013, 08:24 PM | #3 |
Pebble Pounder Join Date: Aug 2012 Location: Gadrock, Al
| Re: rubicon kit
Yes it comes with everything to 4 link in the box, & servo on axle is much better performance wise, cms is more scale tho
03-17-2013, 08:28 PM | #4 |
| Re: rubicon kit
ok cool thanks another question if i went all metal links just pick up 2 98mm and 2 106mm or what ??
03-17-2013, 08:41 PM | #5 |
Pebble Pounder Join Date: Dec 2012 Location: The fun house
| Re: rubicon kit
I have the kit and there is no second link truss in any of the parts trees. I checked and double checked. The build manual shows 3 link front , 4 rear with no other portion listed. I used a dinky rc truss to 4 link the front. Used 8-32 all thread to make upper front links because the new truss dictates custom length.
03-17-2013, 08:45 PM | #6 | |
| Re: rubicon kit Quote:
03-17-2013, 09:30 PM | #7 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: rubicon kit
Rear upper uses 98s on the uppers, not sure which is used with the front upper w/the 4 link mount. Cause I use the upper vanquish servo mount w/the 4link on the fronts. One thing .... When you mount the ball sockets use the ax metal ball sockets for (axa1331) , they wear in better and seem to flex better IMO. Metal on metal, verses metal on plastic, ya know.
03-17-2013, 10:06 PM | #8 |
Rock Crawler Join Date: Jan 2013 Location: Cen Cal
| Re: rubicon kit
I've had good luck running equal length upper and lower rear links. This gets the axle clocked back to get your pinion angle nice and straight (also increasing clearance), but equal front uppers/lowers will give you way too much negative caster which destroys steering performance, and aims your steering links into the ground, so the front uppers will need to be a bit shorter than the lowers unless you have a clockable c-hubs.
03-17-2013, 10:17 PM | #9 |
| Re: rubicon kit
i was planning on getting some so whats the length of uppers of front and back
03-17-2013, 11:14 PM | #10 |
Quarry Creeper Join Date: Jul 2009 Location: Missoula
| Re: rubicon kit
My kit doesn't have an extra 4 link mount either. It does however have an extra 3 link mount, although I don't know why. It does come with an extra set of upper links, just no mount.
03-18-2013, 11:34 AM | #11 |
| Re: rubicon kit
This is strange. Why do some kits get it. I am happy with my set up but at the time I would have liked to have it so I could have used stock links. Maybe I'll give axial a call.
03-18-2013, 12:18 PM | #12 |
Pebble Pounder Join Date: Apr 2012 Location: BritishColumbia
| Re: rubicon kit
i have heard of alot of kits with missing or different parts, i just called them and all was good.
03-18-2013, 12:27 PM | #13 |
Pebble Pounder Join Date: May 2012 Location: Sherwood Park
My kit didn't have an extra 4 link truss either. I wasn't happy with the steering setup. The servo ears hit on the frame, the end of the steering link hit on a crossmember, and then the steering link hit on the left frame rail when I removed that. If you want to stick with 4 link, remove the front crossmember, and then flip the servo and use a longer steering link. Then you'll have full clearance.
03-18-2013, 05:46 PM | #14 | |
http://docs.axialracing.com/instruct...cx10-links.pdf | |
03-18-2013, 05:53 PM | #15 | |
However, the RTR instructions on page 12 has a x2 for the AX80043. | |
03-18-2013, 06:19 PM | #16 |
Newbie Join Date: Feb 2013 Location: Montreal, Quebec, Canada
| Re: rubicon kit
I had the necessary parts in my honcho kit !
03-18-2013, 06:26 PM | #17 |
Quarry Creeper Join Date: Jul 2011 Location: charlotte
| Re: rubicon kit
My kit did not have the extra 4 link mount and it's not shown in the parts tree list in the beginning of the manual.
03-18-2013, 06:38 PM | #18 |
Newbie Join Date: Apr 2007 Location: Wentzville
| Re: rubicon kit |
03-18-2013, 06:43 PM | #19 |
| Re: rubicon kit |
03-18-2013, 07:26 PM | #20 | |
For the front, axial again provides 106 tubes for the lowers. The extra plastic front upper links axial provides are 115 eye to eye. In order to get that with stock axial aluminum tube links you would have to use 87.5 (wraith/ridgecrest) tubes with short straight ends. 98's with ends would be too long. Since my kit did not come with the truss I make 110 eye-to-eye links because the dinky truss moves the mount location of the upper links aft a bit more that the axial mount location. You will want to upgrade to aluminum because the stock plastic links are noodles. Axial has an aluminum link upgrade kit they want to sell everyone I guess. Good thing I read up on this forum on how to make links. All thread works and it was good fun fabing then up, it just does not look as cool. | |
rubicon kit - Similar Threads | ||||
Travis's Rubicon kit | travis4380 | Axial SCX-10 | 17 | 07-12-2015 08:10 PM |
scx-10 kit Dingo or Rubicon | fivel_976 | General Crawlers | 12 | 03-12-2013 04:08 PM |
Rubicon Kit D: $1079 value? Let's compare! | Dailyroost | Axial SCX-10 | 18 | 02-28-2013 08:32 PM |
dingo/cherokee or rubicon kit? | mrcrzrs | Axial SCX-10 | 12 | 02-08-2013 01:47 PM |
Rubicon kit | im gunna crawl | Axial SCX-10 | 4 | 01-17-2013 11:05 AM |
