11-09-2013, 10:24 PM | #21 |
Pebble Pounder Join Date: Sep 2011 Location: Medford
| Re: Matts scx10 action!
I got my bumper painted up, as well as my pull pal today. Turned out good. I just hope the paint is a nice hard finish and doesn't chip off easy. What do you guys think? |
12-30-2013, 10:25 PM | #22 |
| Re: Matts scx10 action! |
01-01-2014, 12:34 PM | #23 |
I got the rear bumper all painted up and it turned out good, as did the shackles. While I was waiting for it to dry I got an itch to make a snorkle. I used some black plastic drip tube irrigation line, an axial light bucket, a large axial rock shield (trimmed to fit and glued) for the screen on the snorkle mouth, a little bit of all-thread and some CA to thread the bucket to and sleeve into the hose. I had to use a little heat to mold the end of the hose to make it look like it turns into the fender. Then some SS wire to hold it to the body. |
01-01-2014, 03:06 PM | #24 |
Rock Stacker Join Date: Sep 2013 Location: Vancouver
I like that snorkel idea might have to copy it. |
01-01-2014, 04:56 PM | #25 |
| Re: Matts scx10 action! Do it up! I got the light bucket part from another rcc member. But he used parts tree plastic for the pipe.. I couldn't find a peice that would look right. And I happened to have some drip line so I snagged about 4" and went at it. Make sure you post pics, I wanna see how yours turns out. |
01-01-2014, 05:06 PM | #26 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
What body is that?
01-01-2014, 06:32 PM | #27 |
Pebble Pounder Join Date: Aug 2005 Location: Monticello
Awesome looking rig. Great job Sent from non supported Xparent Blue Tapatalk that I cant post pictures with and not supported by the developer! |
01-01-2014, 07:34 PM | #28 |
Quarry Creeper Join Date: Dec 2013 Location: ][V][
wish I had the skills to do some custom work like that. sweet rig
01-01-2014, 07:46 PM | #29 |
| Re: Matts scx10 action! To my knowledge and looking around it is a proline 72 chevy c10 body. It came with it when I bought it. I didn't like it that much at first but it's growing on me the more I add to it, like the drop bed and the snorkle and lighting and such.
01-01-2014, 07:47 PM | #30 |
01-01-2014, 07:50 PM | #31 |
01-04-2014, 07:49 AM | #32 |
I got my RC4WD CMS & Panhard kit yesterday from RPP Hobby and installed it! The kit is nice and easily built. It had everything I needed for install. I used the install instructions from the RC4WD website https://store.rc4wd.com/mobile/product.asp?itemid=3391 Anyways, very happy with it so far. I highly recomend it. So onto some pics Before: The goods: Installed: And the casualties of the awesomeness of the CMS kit: (a bunch of plastic screws left the scx10 also ) |
01-04-2014, 09:07 AM | #33 | |
| Re: Matts scx10 action! Quote:
01-04-2014, 10:04 AM | #34 | |
Quarry Creeper Join Date: Sep 2012 Location: home
That may have somthing to do with your guys link setups man, his rears may be shorter while his fronts are longer and yours could be opposite. I don't think there should be a 2in difference tho but you never know. I also noticed that his shock towers are mounted in the dingo holes while yours are in the honcho holes but I don't think that has anything to do with it. But like I said, you never know - Richard | |
01-04-2014, 11:20 AM | #35 |
I did move my rear shock hoops in to the dingo holes and have slightly shorter rear links that I made. They way the PO had the holes drilled in the body he had it way forward and the rear tires hung out the back so I tucked them in and that's why my WB is a bit shorter and the bumper is snug to the frame rails. He also hogged out the wheel wells and that makes a huge difference as to where the body can ride. You can make a visual reference with the rock sliders to the body lines. |
01-04-2014, 11:48 AM | #36 |
Ok cool..shorter wb makes sense why mine is different.
01-04-2014, 07:22 PM | #37 |
Yeah my WB is about 12.0" if I remember right. Kinda in between a honcho and dingo. I like it.
01-05-2014, 10:21 PM | #38 |
01-08-2014, 10:42 PM | #39 |
Oh I've been busy with this truck and I think it's almost done (?) So the updates are I: -Flipped my winch and wired it out the drivers side -Made an aluminum doghouse over the tranny to mount my electronics box and mamba to -Made an aluminum battery mount, using the stock plate -Installed the RC4WD CMS kit (awesome) -Shaved the servo mount post off the front axle -Made the cb whip antenna and spring mount -Made a snorkle -Made some fishing poles And here come a mass amount of photo greatness! |
01-21-2014, 11:48 PM | #40 |
| Re: Matts scx10 action! Thank you!! I really like how the they fit as well! Not to bad for a first try. The only down side is if I ever get a new body the bumpers aren't going to be so fitting... Bummer
Matts scx10 action! - Similar Threads | ||||
Matts Wraith Action! | Matthewboerner | Axial Wraith | 59 | 10-09-2013 09:19 PM |
Matts Mini GC-3 *2011 Build* | MRCCRAWLER1.9 | Losi Mini-Rock Crawler | 32 | 02-10-2012 12:43 AM |
Green design/engineer matts?? | Arctic Fire | Newbie General | 2 | 12-04-2011 02:30 PM |
My SCX10 in action | fullspeeddesign | 1.9 Scale Rigs | 9 | 07-21-2010 09:48 PM |
SCX10 in Action........... | BENDER | Scale Videos! | 22 | 05-05-2009 06:21 PM |
