Thread: My "Cheap as I can find it" Build.
Old 08-03-2013, 08:56 PM   #1
Default My "Cheap as I can find it" Build.
It started with an idea of how cheap could I really build one using new and used parts. So I started stalking late night auctions.You know the ones. The ones that end at 3:00am and hardly anybody bids on them.
Well I scored some good stuff on those auctions. I got a complete new chassis for $28.50 shipped. I got a set of used (but not hurt) stock shocks for $12.00 shipped. A bunch of rtr links and four link trusses for $10.00 shipped. And a Tamiya F350 body new for $18.75 shipped. All this was done over a 3 week period with many late nights and early mornings....lol There were only the three links so I bought some all thread, brake line, and rod ends for around $18.00. For other used parts I had were a set of axles, a tranny with RR metal gears, Drive shafts, and some 1.9 ripsaws from a rtr.I'm far from done but I'm still looking for that next deal on something to add to the build. Here's some pics.
T I N Y is offline   Reply With Quote
Old 08-03-2013, 09:08 PM   #2
Default Re: My "Cheap as I can find it" Build.
nice find i too am trying to stake out eBay and Kijiji to find parts for a 2nd crawler
pvo_srt4 is offline   Reply With Quote
Old 08-03-2013, 09:25 PM   #3
I just placed an order for Holmes Hobbies new Trail Master sport 540 motor for $11.99. It's not the greatest motor that you can get from HH but it's still HH. And they don't put out junk!
Here's the specs:
The Trail Master Sport 540 is a budget motor built for messy, dirty action. Whether on the rocks or in the dirt, the Trail Master Sport is perfectly at home. Sealed can construction with spring mounted brushes and bronze bushings for running in the muck without worrying about ruining an expensive motor.
"540" motor size
27 turn
Zero timing, universal installation and rotation direction
1/8th inch shaft diameter
m3 mount holes, 25mm spacing
bronze bushings
Old 08-03-2013, 09:25 PM   #4
Good luck.
Old 08-03-2013, 10:06 PM   #5
Here's the specs:
"540" motor size
27 turn
bronze bushings
I'm really curious how these motors will hold up. I've got a couple of beater rigs these would slide nicely into...
spankbomb is offline   Reply With Quote
Old 08-03-2013, 10:27 PM   #6
A Holmes motor for $12 .....ya, I'm interested also
Postclanker is offline   Reply With Quote
Old 08-04-2013, 07:39 AM   #7
Might be a good replacement when my axial 20t goes out
Stangman92 is offline   Reply With Quote
Old 08-04-2013, 02:05 PM   #8
I'm doing some body work today..Filling holes and such...I'll add pics later tonight.
Old 08-04-2013, 03:33 PM   #9
Where did you find that Holmes motor for $12?
Constantly updated from my Iphone using Tapatalk forum App
-Mobsteel- is offline   Reply With Quote
Old 08-04-2013, 03:38 PM   #10
On holmeshobbies.com...lol
Holmes Hobbies LLC
Old 08-05-2013, 05:50 AM   #11
Nice! A Holmes Motor 27T! And you only payed $12 for it. Wow, Nice! I should gimme one of thos for a Franken Build I'm starting
TennesseeCrawler is offline   Reply With Quote
Old 08-05-2013, 10:56 AM   #12
What did you use for steering servo?
ihatemycherokee is offline   Reply With Quote
Old 08-05-2013, 11:20 AM   #13
The pictures show a 645.
Calderwood is offline   Reply With Quote
Old 08-05-2013, 12:39 PM   #14
Yep a hs 645 mg but I'm not sure if it's going to stay just yet.
Old 08-05-2013, 01:35 PM   #15
nice! Curious to see your total
Richterat83 is offline   Reply With Quote
Old 08-05-2013, 02:06 PM   #16
Me too...I'm getting away kind of easy because I had some of the main components already. Axles, Tranny, Tires, wheels, And I have a couple different Esc's to pick from.
Old 08-05-2013, 09:32 PM   #17
Go with a 400 oz servo from Solar Servo $17, overkill for the scx10 with 1.9's
Demodude is offline   Reply With Quote
Old 08-09-2013, 02:41 PM   #18
I got my motor from Holmes Hobbies today.So I hooked it up and took it for a bench test. Let me tell ya this $12 motor is worth every cent. I'm running it with a Novak Rooster on 84/16 gearing and from a dead stop to top end this thing is as smooth as glass. I can see these motors being a huge hit with the TTC guys for sure.I also had a chance to mock up the body also. I think it's working out ok so far.
Old 08-13-2013, 02:34 PM   #19
I did some body work the last couple days.. I want to give a big thanks to HOOSIERDADY from the CHOP SHOP for the big tip on filling in the holes on the sides and the antenna hole.And just in case you don't know The Chop Shop turns out the sickest hard body customs there are. If you're looking for some hard body work to be done he's the guy to do it. But any way Here's how mine turned out.
Old 08-13-2013, 02:45 PM   #20
Fan of wheelspeed
Very nice work filling those holes TINY. I'm curious to see where the total ends up on this build too. Now you've got me searching those 3am auctions, lol.
Hoosierdady is offline   Reply With Quote
My "Cheap as I can find it" Build. - Similar Threads
Jkabee's "total noob" TJ build "this should be fun!" jkabee Axial SCX-10 128 03-24-2013 12:10 PM
Chaotic Crawlers "DEMON" build! aka "Kreacher" Mac10 EnRoute Berg 96 09-26-2010 01:49 PM
Project "As Cheap as I can build it". tjcrawler Tamiya Clod Buster 23 04-29-2007 09:51 AM
"Fer Cheap" crawler build Mr Badwrench Tamiya TLT Crawlers 30 01-14-2007 09:15 AM
