02-08-2014, 05:30 PM | #21 |
| Re: Axle skid (scuff plate)
well here is a prototype, rough draft bolted up, I know there needs to be some cleanup work done to it but I am generally pleased with the design so far.
02-08-2014, 07:18 PM | #22 |
here is a revision...if the lower holes are used for mount in the front, they stick out and will catch on everything, that is the reason for mounting the front on the upper bolts
02-08-2014, 08:58 PM | #23 |
here is a simpler version
02-08-2014, 10:03 PM | #24 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
I cut up a coke can and made a skid just along the center line. when the skid wears out I tear it off and replace it (hot glue for the win)
02-09-2014, 12:01 AM | #25 |
this is the version I am going to try...it will last a long time...
02-09-2014, 03:52 AM | #26 |
RCC Addict Join Date: Feb 2012 Location: UK
I think that is a great idea/design. I was concerned of the wear but it was drastically reduced when I moved to 2.2 tires. I also try and drive a line to avoid hitting the pumpkin although not always possible as we all know! :-) Sent from my HTC One X using Tapatalk |
Axle skid (scuff plate) - Similar Threads | ||||
junfac axle skid plate | stunter38 | Axial SCX-10 | 3 | 07-05-2013 12:09 PM |
Measurements for stock AX10 Transmission mounting plate/skid plate | Apoch | Axial AX-10 Scorpion | 5 | 04-09-2012 07:53 AM |
Skid Plate - axle | jimjam | Tamiya CR-01 | 10 | 05-12-2011 08:03 PM |
skid plate | gearstripper | Newbie General | 4 | 01-31-2010 03:09 PM |
