03-23-2014, 08:10 PM | #1 |
Newbie Join Date: Jan 2012 Location: Anderson
| Axial jk shock help??
What kind of shocks can I put on my jk that will lift it some and keep the body roll to a minimum and still let it articulate ! It seems that when I'm on a hill it seems to roll over on the shocks but once the weight shifts it comes on over ! Any help would be greatly appreciated thanks!!
03-23-2014, 08:14 PM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Axial jk shock help??
Pro-Line Powerstrokes for the Slash are a great shock to go with. However, before you spend that money, mess with the shock oil and spring rates.
03-23-2014, 09:48 PM | #3 |
Quarry Creeper Join Date: Nov 2007 Location: Orygun
Agreed. Buying new shocks won't help you. Spring rate sand oil weights are what makes a difference. The only thing different shocks have to offer is different dimensions and a lighter wallet.
03-24-2014, 05:54 AM | #4 |
Pebble Pounder Join Date: Nov 2009 Location: Paulding
The reason I bought new shocks is because the stock plastic ones leak. The proline do not leak at all. I am running the scaler proline shocks and I love them..! Sent from my iPhone using Tapatalk |
03-25-2014, 04:49 PM | #5 |
| Re: Axial jk shock help?? Yes and lifting it will make it roll over even more. 30 - 40 weight shock oil in stock shocks or Proline Scalers should work fine unless your truck is really heavy, then you'll have to play with oil and stiffer springs.
03-25-2014, 04:57 PM | #6 |
Rock Crawler Join Date: Jul 2011 Location: Placer County
what are the rest of the specs on your rig? stock electronics placement? any weight in the wheels or in the axles? how are your driving skills? i would start with this stuff first before swapping shocks. A bone-stock RTR scx10 out of the box is a VERY capable rig that has already been proven to beat many built rigs if you know how to drive it. |
Axial jk shock help?? - Similar Threads | ||||
Axial Shock Set | JB Kelley | Newbie General | 11 | 08-12-2010 05:22 AM |
Axial shock pistons in big bore shock bodies | Kanine38 | Newbie General | 2 | 03-11-2010 06:47 AM |
Axial Shock Opinions | person123 | Newbie General | 22 | 01-28-2008 08:37 PM |
Axial SHOCK problems | quads4_life | Axial AX-10 Scorpion | 34 | 09-12-2007 10:40 PM |
