Thread: Brushed motor choices???
Old 03-30-2014, 09:06 AM   #1
Default Brushed motor choices???
Id like to get a new motor for my fairly heavy scx10, its streched to fit the 4 door newbright body, weighted front tires. im not looking for much speed, but it would be nice for it to go faster than i can walk when needed, but still have enough torque for crawling. i run the stock esc, 1800mah 2c lipo (can run 2 if needed) i have a 55t hpi with 80/23 and its ok but could be a little faster. i also tried a 12t but it had no torque. Am i asking for to much and should just be happy with the way it is now?
BeerMonkeY is offline   Reply With Quote
Old 03-30-2014, 09:16 AM   #2
Default Re: Brushed motor choices???
i'm running a 45t inegy motor with stock spur gear and a 18t pinion and it seems pretty good.Little faster than i can walk, good torque .
DORM is offline   Reply With Quote
Old 03-30-2014, 09:47 AM   #3
Look for a good quality 27t-35t motor like a holmes torque master or a 13t crawl master which has speed of a 27t. Gear down to around 16/87 and run it on 3s lipo. Quicker than a fast walk and plenty of torque.
cottoneyed Joe is offline   Reply With Quote
Old 03-30-2014, 10:07 AM   #4
I run a Novak Rockstar 35T, with stock spur and 16t pinion on 3s. Top speed is faster than a fast walk, and has good torque.
Airdet is offline   Reply With Quote
Old 03-30-2014, 10:16 AM   #5
I run the Holmes Hobbies 27T trailmaster sport. It's a great little sealed can motor and it's only $12.00. It's got plenty of torque and nice wheel speed...
T I N Y is offline   Reply With Quote
Old 03-30-2014, 10:36 AM   #6
I run a 35t tekin motor and it is the best motor I have ever owned. It has a lot of torque and a good amount of wheel speed.
79SCX10 is offline   Reply With Quote
Old 03-30-2014, 10:39 AM   #7
I use the Integy 35t. Lots of run time and plenty of TQ.
tstmonkey is offline   Reply With Quote
Old 03-30-2014, 10:45 AM   #8
for sure go with a quality brushed motor 27T-35T range for good torque and good wheel speed..I personally run a 27T Holmes Hobbies Torque Master Sport, 27T Holmes Hobbies Torque Master Expert and a 30T Holmes Hobbies Torque Master Pro and they all are great!
allanon1965 is offline   Reply With Quote
Old 03-30-2014, 11:32 AM   #9
You could also go with Team Brood motors, they are great motors Whatever brand you decide get a 27t to 35t, good mix of torque and speed
billj is offline   Reply With Quote
Old 03-30-2014, 11:45 AM   #10
Integy 35T on 4s
Johnnysplits is offline   Reply With Quote
Old 03-30-2014, 12:04 PM   #11
throw away Axial 55T W/ 3S LiPo 87/14 (48p) on 1.9's
volt up/gear down
^ brings 'dat cheapo motor to life
TacoCrawler is offline   Reply With Quote
Old 03-30-2014, 12:05 PM   #12
My best luck has been with 35t handwounds. Tekin or HH have never let me down. I had heat issues when running a 27t in my heavy 6x6 and went back to a 35t.
Kling-On RC
"The Original Spot to Let Your RC Hang"
www.klingonrc.com
www.shop.klingonrc.com
Propane is offline   Reply With Quote
Old 03-30-2014, 02:25 PM   #13
how many of you run 3c? ive read you can do it on the stock axial esc if you run a bec, is this correct. i can only run a small battery due to the body.
Old 04-02-2014, 05:28 PM   #14
So i threw in a 3 cell and it made a big difference, think im gonna go a size or 2 bigger on pinion and run a 3 cell
Old 04-02-2014, 05:39 PM   #15
I run 55t with 87 spur and anywhere from 16-21t pinion. Never had any issues.
Shinjari is offline   Reply With Quote
Old 04-02-2014, 08:23 PM   #16
35T hand wound on 3s would get my vote. I'm running a 35t machine wound torquemaster sport on 3s and it is awesome, the hand wounds are even better.
alpine4x4 is offline   Reply With Quote
Old 04-03-2014, 12:18 AM   #17
35t Tekin on 3S, stock 20/87 gearing. Running similar 35t Novak on 3s with 20/80 gearing in my Wraith. I wouldn't go with a much slower configuration. In some situations I find a little wheelspeed helpfull, even if I rarely use all of it. If I ever experience motor heating I'll drop some tooths on the pinion.
If I where to stick just with 2S I would have gone for a 27t motor, or possibly even faster. Traxxas Titan 550 21t is a cheap solution that will provide some speed, but it probably won't outlast a proper rebuildable 35t.
Odd-M is offline   Reply With Quote
Old 04-04-2014, 06:32 AM   #18
Yes, you can run a 3s lipo on the stock esc when using a bec.
Brushed motor choices??? - Similar Threads
Out of my element.. 3s motor choices? monkeymagic9 Rally 7 09-24-2013 09:29 PM
brushless motor choices? idaho Electronics 19 09-12-2013 11:48 PM
motor choices ultimate_monkey Electronics 16 04-08-2010 08:02 AM
Motor choices... JSN Venom Creeper 4 02-15-2009 11:18 AM
Motor Choices Mriccucci Electronics 5 06-05-2007 08:55 PM
