03-30-2014, 09:33 AM | #1 |
Quarry Creeper Join Date: Sep 2010 Location: Maine
| novak SS+ brushless set up
so i put a novak Super Sport Plus esc and a SS5800kv brushless motor combo in my truck. the day i soldered everythin up, it worked great, it would stop for a second but all i had to do was give it a little nudge with my boot or go in reverse and itd kick bak on. yesterday went to go plug in my battery(2s lipo) and i get nothin. when i pull the throttle the green light comes on then the green light and blue light on the esc starts to blink and i get nothin even with nudgein it forward. them reverse is the same way, the green light blinks then the blue light comes on and the green and blue light blink and nothin happends. im not sure if it needs to be programmed, if the motor is burnt out or what. im runnin a 2.4ghz radio from a nitro exceed buggie. thanks for the help!
03-30-2014, 09:58 AM | #2 |
Rock Stacker Join Date: Sep 2013 Location: Vancouver
| Re: novak SS+ brushless set up http://teamnovak.com/file_download/1...tPlusInstr.pdf According to that it's a possible ESC shut-down due to locked rotor detection. Return to neutral and check drivetrain for any binding. |
03-30-2014, 10:06 AM | #3 |
everything moves freely. i was thinkin if i took the motor apart and cleaned it, maybe there might be dust or something inside
03-30-2014, 12:13 PM | #4 |
took it apart and cleaned it with compressed air. put it back together. didnt hook it up to motor mount and turned the truck on and started doin the same thinv. so must be a dead spot in the motor. or the motors junk
novak SS+ brushless set up - Similar Threads | ||||
What your thought on Novak Timbuk2 "Wraith Edition" Brushless ESC/Ballistic Brushless | Driller1 | Electronics | 10 | 07-02-2012 09:26 PM |
Novak Releases "The Goat" brushed/brushless esc and sintered brushless motor | Rockpiledriver | Electronics | 70 | 09-26-2007 05:59 PM |
Novak Super Sport Brushless ESC + Novak Crawler Motor | Scattman | Electronics | 10 | 03-13-2007 08:27 PM |
