07-17-2014, 09:27 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Brackenfell, South Africa
| Help with switching to 3s
Ok so I need some help with the motor/ESC combo for my new kit. I've always just stuck with the standard stick pack or 2S LIPO, but I read about you guys using 3s for extra wheel speed, and low down power. So my question is: Will the standard Axial 27turn brushed motor handle 3S? And my second question is, what cheaper ESC can handle 3s? I don't need to point out that I live in South Africa, so more than likely I'll have to import the motor and ESC. But please give me some advise guys.... Thanks |
07-17-2014, 09:44 AM | #2 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Help with switching to 3s
Motor should be fine. But, if you want to upgrade to a really good motor a Holmes Hobbies motor in the same amount of turns would be a good choice. A torque master would be a good start. As for an esc, the Castle creations sidewinder is cheap-ish esc that can handle 3s. I have one in my scx and it handles 3s no problem. I'd get the castle link to so you can program it from the computer. So much easier. |
07-17-2014, 11:29 AM | #3 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
What ESC do you have now? It has been shown that the AE-2 ESC can handle 3S just fine with the addition of a $20 Castle BEC. It's a smart move to have a BEC in a crawler anyways, so it may be a good idea to look at picking one up.
07-17-2014, 11:39 AM | #4 |
I don't have anything yet. Just recently made my mind up on the G6 kit. So I have a blank canvas to start with... In fact I don't even have 3S LIPOs. I might have to borrow one from my dad for the test... |
07-17-2014, 11:42 AM | #5 |
I ran the stock axial esc on 3s for many months with a BEC and a holmes hobbies 30T torquemaster expert motor with no issues, I eventually upgraded to a mamba max pro and a tekin redline 13.5 brushless combo and have been very happy with that once I set the timing on the motor to zero(due to reverse rotation)
07-17-2014, 12:08 PM | #6 |
Ok without sounding like a complete noob, I am running a BEC in my other SCX10, but only on the steering servo. How would I connect the castle BEC to the Axial AE-2 to make it 3S compatable? |
07-17-2014, 01:38 PM | #7 | |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: Help with switching to 3s Quote:
So the external bec, which in most cases in much more capable than the internal bec, handles the brunt of the electrical needs. Reducing strain on the ESC, thereby reducing heat and extending the life of your ESC. There are many threads dedicated to this topic in great detail, but it seems like you are doing it right. Either run the bec to your receiver at the appropriate voltage or straight to the servo. Remove the ESC red wire if wiring to the RX. | |
07-17-2014, 02:29 PM | #8 | |
07-17-2014, 11:23 PM | #9 |
Ok thanks, so the BEC is basically just to bring the 3s (11.1v) down to the correct voltage for the receiver? The way I'm using it, it's to provide the servo only with more grunt 6v/6a. But the one question I have, is the AE-2 specs say it can only handle 2S. That is my real concern... I build my own BECs, using a voltage regulator. They work very well, but for this I think I'll use a proper BEC... |
07-18-2014, 05:36 AM | #10 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Help with switching to 3s |
07-18-2014, 08:26 AM | #11 |
07-19-2014, 03:42 AM | #12 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
I've run my AE-2's on 3s. I own three of them now, and any time i can snag one off of a classified ad i do. Great esc's
Help with switching to 3s - Similar Threads | ||||
Switching to MIPs | NewbieRC361 | Axial Wraith | 12 | 09-14-2013 07:46 AM |
Switching to lipo? | RallyeX | Axial Wraith | 5 | 04-08-2013 10:07 PM |
Switching to LiPo | scoggdog13 | Electronics | 2 | 03-24-2013 05:30 PM |
switching to lipos | schiller_18 | Electronics | 7 | 08-01-2012 11:21 PM |
Switching brushes? | demonoid369 | Electronics | 10 | 04-28-2011 02:22 PM |
