08-14-2014, 11:01 PM | #1 |
Newbie Join Date: Aug 2014 Location: Phoenix
| Spur gear
I have two scx10's on is the deadbolt and the other is the honcho. I was working on my deadbolt and noticed the spur gear setup is completely different than the honcho, there is a bigg difference in tooth count and slipper design. I was wondering if you guys know which is the preferred design. I need to change the gear on the deadbolt and was wondering if it would be a downgrade to use the honcho setup or if it would even work. Thanks!
08-14-2014, 11:17 PM | #2 |
Rock Stacker Join Date: Mar 2014 Location: HK
| Re: Spur gear
the Dead bolt has a dual slipper clutch and 32 pitch spur gear, which will take higher torque and easier to tune
08-14-2014, 11:36 PM | #3 |
Rock Crawler Join Date: Apr 2009 Location: bend
| Re: Spur gear
Your deadbolt has upgraded 32 pitch gears. You could upgrade your honch to make the part easier to switch out between rigs.
Spur gear - Similar Threads | ||||
Is there a metal upgrade gear for the 80T spur gear? | maddogs1965 | Axial Wraith | 9 | 03-25-2014 11:31 AM |
Which pinion gear works best with RC4WD Steel spur gear? | e32lover | HPI Wheely King | 8 | 03-10-2013 06:09 PM |
Which spur gear and pinion gear with 35t motor | vegas1973 | General Crawlers | 1 | 08-19-2012 11:42 AM |
Micro T spur and Micro Crawler spur gear. Same thing? | matts175 | Losi Micro-Rock Crawler | 4 | 10-15-2011 01:18 AM |
Wobbling spur gear....Need alum. gear hub! | sickfab | HPI Wheely King | 26 | 10-01-2007 02:09 AM |
