09-10-2014, 06:43 AM | #1 |
Newbie Join Date: Sep 2014 Location: Mid-Coast
| What should be 1st mod!
I just picked up my first axial G6. It if my first crawler and trying to digest all the info! With that said, what should be my first mod if there is a part or parts on it that tend to break more easily than others?
09-10-2014, 06:55 AM | #2 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
| Re: What should be 1st mod!
Steering links & lower links kinda like wet noodles on most with it being plastic be a good upgrade! Then as you break(if ya do)stuff upgrade as ya go unless you wanna spend more cash up front!!! All depends on how you drive it & what you want it to do...good luck |
09-10-2014, 07:21 AM | #3 |
Quarry Creeper Join Date: Jul 2013 Location: Toronto
i would do the F/R and steering link 1st up. There is a guy on youtube that has a great how to https://www.youtube.com/watch?v=Deeew4LJRIo here is my G6 post build and so far the truck fairly stock does great and beats up on those $1000 rigs at local comps PVO_SRT4's G6 Post Build |
09-10-2014, 07:47 AM | #4 |
Pebble Pounder Join Date: Nov 2010 Location: wyatt
first mod, install battery, then bash away till it breaks. also you should go through and make sure all hardware is tight.
09-10-2014, 08:04 AM | #5 |
Drive until it breaks or it won't do something that you want it to do. Then fix that problem. Then drive it until you hit the next problem. You will learn more about your rig and what the mods really do or in some cases don't do. You will also be a lot less likely to get bored with it and put it on the shelf and forget it. |
09-10-2014, 08:13 AM | #6 |
Pebble Pounder Join Date: Mar 2011 Location: Wales,UK
If you haven't already, read the tips n tricks thread - there are some free mods that can be done if you feel they are beneficial for your use. Tips and Tricks Thread |
09-10-2014, 05:39 PM | #7 |
Rock Stacker Join Date: Jul 2014 Location: Hillsboro
I upgraded the links right away, added a winch, moved the battery up front and I did get some better crawler tires. Stock Maxxis Trepador on the JK just dont cut it on the rocks.
09-10-2014, 06:35 PM | #8 | |
Rock Stacker Join Date: Jul 2013 Location: Somewhere
| Re: What should be 1st mod! Quote:
The G6 is my first crawler, and I can't believe how well this thing climbs for me. Even the durability has exceeding my expectations. Had a few barrel rolls down really long steep hills that resulted it landing into trees, rocks, or other things...definitely enough to make me cringe. So far no damage. For reference, mine is the kit version with the stock motor, a brushed ESC with mild drag break functionality, and a Hitec 7955 servo with a BEC. I am really happy with it and always look forward to driving it. | |
09-10-2014, 06:57 PM | #9 |
Ok.....Let the breaking begin and the mods after! LOL Thank you for the input! I will check out the links
09-10-2014, 07:45 PM | #10 |
Rock Stacker Join Date: May 2013 Location: Marietta
Metal lower links and steering link for sure...my sons new deadbolt was good for about 3 packs. After that, the tires would point which ever way they wanted. You know at the supermarket when you get the cart with the bad caster wheel thats always wobbling? Thats about what it was like.
09-10-2014, 08:50 PM | #11 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
I agree with sic1to do steering links and upper and lower links. You could make them or buy a kit axial, or vanquish products.
09-10-2014, 08:56 PM | #12 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
G6 Recon kit or G6 Falken RTR? The Recon kit comes with aluminum steering and lower links. |
09-10-2014, 09:06 PM | #13 |
Quarry Creeper Join Date: Aug 2013 Location: Bullard TX
Best mod is driving time and upgrading as you break stuff. You don't want to spend money on a mod you think you need now just to realize it was wasted money and is now holding you back.
09-11-2014, 02:45 AM | #14 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
Aluminum servo horn. Stock plastic one stripped first time out.
09-12-2014, 11:55 AM | #15 |
| Re: What should be 1st mod! |
09-12-2014, 12:30 PM | #16 |
09-12-2014, 06:10 PM | #17 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
a lot of mods also depend on your style of driving which you don't even know yet, so definitely put some hours in it behind the wheel before you decide what you think you even want to get a fast motor slower motor upgrade gears , under drive gears the list goes from there but you get idea.
09-13-2014, 11:25 AM | #18 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
Im going with what bayaeraaxial said...just drive it and see what fails on you and replace as needed...if you drive the truck sensible and dont beat it to death you wont really need to replace very much at all and can concentrate more on upgrades that actually improve performance...i still have yet to break parts i was told would break on me and recommended expensive parts...we all want something different and you will get alot of different advice....some is very good advice...some is bad and some are just sales pitches...Good luck to you on your trailing adventures. My personal advice to get you started: Replace the steering links. Replace at minimum the lower suspension links (convert to 4 link up front) Change your motor pinion to a 16t gear.. (if you have an rtr) Use a 2s lipo to get started with..you can decide if you need more or not down the road. Last edited by 6sharky9; 09-13-2014 at 11:30 AM. |
What should be 1st mod! - Similar Threads | ||||
VA-Scaler hosting 1st Camel Trophy Team Challenge June 1st, 2013 | mjderstine | Competitions | 71 | 08-18-2013 07:56 PM |
1st mod on the Honcho! | scx_dave | Axial SCX-10 | 52 | 07-25-2013 04:37 PM |
VA-Scaler hosting 1st Camel Trophy Team Challenge June 1st, | mjderstine | Virginia | 13 | 07-12-2013 04:04 PM |
My 1st Crawler, 1st Comp, 2nd place novice class | pinckbrown | Axial XR10 | 23 | 03-01-2011 08:46 AM |
