Thread: G6 Shock oil
Old 11-12-2014, 02:40 PM   #1
Default G6 Shock oil
What's the hot trick to keep the oil in these shocks? I will be headed to Reno for the G6 coming up, and I know that the high elevation will push it out. Are there any better seal set ups for these?
Hotrodvw is offline   Reply With Quote
Old 11-12-2014, 03:10 PM   #2
Default Re: G6 Shock oil
Rebuild them at the altitude of the event the night before the event
DrDiff952 is offline   Reply With Quote
Old 11-12-2014, 03:11 PM   #3
A temporary fix for an evident problem.
Old 11-12-2014, 06:55 PM   #4
Have you used Green Slime on the o-rings? (probably a dumb question)
My stock shocks leaked no matter what I did. I eventually threw in the oil soaked towel and bought some pro line scalers...
Hirschowl is offline   Reply With Quote
Old 11-12-2014, 07:11 PM   #5
No, I haven't done anything as of yet. Did the slime help? I wonder if a Bladder would help.
Old 11-12-2014, 07:28 PM   #6
using some of the Associated Green Slime on the o rings help with a better seal. I use it on all of my shocks to help prevent leaks.
Old 11-12-2014, 07:49 PM   #7
I'm pretty OCD when it comes to shock assembly. The right amount of green slime, just a little teflon tape on the threads, taping over the threads on the shock shaft to prevent knicking an O-ring during assembly, precise bleeding.
Well, it doesn't seem to matter much with the SCX series of shocks. They all leak so bad I've given up on rebuilding them and just consider topping of the oil to be regular maintenance.
meatmonkey is offline   Reply With Quote
Old 11-12-2014, 08:10 PM   #8
rc bros egressor shock bodies with big bore rebuild kit!
Egressor Delrin Shock Bodies | RcBros Hobbies
sic1to is offline   Reply With Quote
G6 Shock oil - Similar Threads
motor oil as a shock oil? Mr.JayDeeM General Crawlers 10 09-02-2012 10:59 PM
shock oil wt. 04rubi General Crawlers 1 01-30-2012 08:51 AM
Shock oil and shock spring help entropy General Crawlers 10 01-29-2011 08:40 AM
best shock oil and gear oil j4k3 Axial SCX-10 2 07-26-2010 12:48 PM
