Thread: Differential gear mesh (underdrive)
Old 01-04-2015, 07:56 AM   #1
Default Differential gear mesh (underdrive)
Just installed a set of Axial underdrive gears, and it feels like there's an issue with the gear mesh.
I double checked the pinion bearings, because I know that's a common culprit, but the pinion seems properly seated.
It seems to be an issue with the differential or ring gear, but I'm not really sure what to look for there. Again, all the bearing seem properly seated.
Perhaps it's an issue (piece of grit) between the carrier and the ring gear?
Ideas?
EDIT:
So, I looked closer at the two ring gears, the stock and the UD, and I noticed that the center recess is more shallow on the UD. Instead of tightening against the carrier, the gear was actually tightening against the locker.
I assume this might be due to the lack of a gasket, part AX30385, which would typically be sandwiched between the carrier and the ring-gear when running a geared differential.
There's no point in running oil with the locker, so instead of the proper gasket, I cut out some card-stock, which I imagine is about the same thickness as the gasket would be.
*Poof*
Perfect mesh.
summerof95 is offline   Reply With Quote
Old 01-04-2015, 11:40 AM   #2
I joined the Band!
Default Re: Differential gear mesh (underdrive)
The gasket is in the kit instructions even with the lockers, although it's only .5mm thick (.020") you see it can be a problem when left out of the build.
Eric0424 is offline   Reply With Quote
Old 01-04-2015, 02:24 PM   #3
I never needed the gaskets with my UD gears or OD gears in my axles mine meshed perfectly w/o them
Tom95YJ is offline   Reply With Quote
Old 01-04-2015, 04:55 PM   #4
I joined the Band!
There's no guaranty one way or the other, just depends on how far out of spec the parts are. Most won't have a problem with or without the gasket, but occasionally a few will.
Old 01-04-2015, 07:41 PM   #5
Originally Posted by summerof95 View Post
Just installed a set of Axial underdrive gears, .....
*Poof*
Perfect mesh.
THANK YOU!
And now I have this set aside for when I install mine if there are any problems.
TakeOffYouHoser is offline   Reply With Quote
Old 01-05-2015, 06:36 AM   #6
So I thought: "Gee, this gasket seems pretty important to proper gear mesh. I wonder why this RTR didn't come with them installed."
Well, then I had a sudden "D'oh!" moment.
On the left is a gear with the gasket installed. On the right is a gear with the gasket removed.
Looks pretty darn similar, eh?
As it turns out, the stock and UD gears are not really machined to different measurements. Despite examining all the gears pretty closely, and washing them in hot soapy water, I COMPLETELY missed the fact that there's still a gasket stuck to one of them.
Old 01-05-2015, 08:30 AM   #7
I joined the Band!
It doesn't help that the gasket is a same color as the gear. If you look close enough you can see it, but you already know it's there. It's a little easier to find.
Our gears aren't actually machined, they're either cast or MIM or some other molding/casting/forming process. Machining leaves behind telltale signs of being cut. A lot of small complex parts are MIM these days, like the lockers our ring and pinion gears, done right MIM parts can be as strong as some machined but at a fraction of the cost to make.
Old 01-05-2015, 10:05 AM   #8
FTR the Axial HD beveled gears don't come with those posts to hold the gasket in place. No big deal. Just mentioning it. I still used the gasket when installing mine.
Axial Racing - Axial Heavy Duty Bevel Gear Set - 43T/13T
GodSpeed999 is offline   Reply With Quote
Old 01-05-2015, 10:12 AM   #9
this is some good info here, something you dont think about...
i have a set of gears that arent as smooth as i would like, going to give this a try. I bet the gasket is missing, or doubled up
Thanks!
Kylar is offline   Reply With Quote
Old 01-05-2015, 11:24 AM   #10
I joined the Band!
Those gears probably are machined, actual steel, spiral cut teeth, better/stronger/quieter gear mesh. Look a lot better than the stock kit and RtR gears.
I plan on upgrading to some of these, but I need to actually drive the Wraith and Dingo a while and see what breaks or wears out.
Old 01-05-2015, 09:19 PM   #11
Common parts to break on a dingo. Tranny gears, stock r&p wear then start popping. Driveshafts break. OD mated with UD are awesome in my dingo
Differential gear mesh (underdrive) - Similar Threads
Bad Mesh on bevel gear and diff gear out of the box? Elliott000 Axial SCX-10 3 08-19-2011 06:37 PM
Underdrive in the rear differential Kanine38 Axial AX-10 Scorpion 41 04-05-2010 06:36 AM
bevel gear, ring gear mesh rocksteadily Tamiya TLT Crawlers 5 05-09-2009 12:04 AM
ax-10 gear mesh goblin79 Axial AX-10 Scorpion 4 02-13-2009 10:22 AM
gear mesh???? traylor4x4 Tamiya Clod Buster 3 12-22-2006 10:11 AM
