Thread: question on scx10 front axle
Old 06-29-2015, 09:29 PM   #1
Default question on scx10 front axle
Hi guys. I put the hot racing aluminum knuckle and C hub on my scx10 and now after a couple trail runs the screw comes lose from the C hub. Sometimes the screw will almost come out. Any suggestions?
humve is offline   Reply With Quote
Old 06-29-2015, 09:31 PM   #2
Default Re: question on scx10 front axle
Maybe you stripped the thread into the axle...you may try with some glue...Or add the beef tubes!
slimfire is offline   Reply With Quote
Old 06-29-2015, 09:49 PM   #3
I don't think they stripped out. I did lock tite them. What is a beef tube?
Old 06-29-2015, 09:52 PM   #4
http://www.rccrawler.com/forum/showthread.php?t=363270
Old 06-29-2015, 09:52 PM   #5
Scale Detail Engineering
loctite should hold them in... did you replace the stock screws with machine screws?
johnnyh66 is offline   Reply With Quote
Old 06-29-2015, 09:53 PM   #6
Must do!
Old 06-29-2015, 10:21 PM   #7
I replaced the screw that came with the C hub. They where not a fine thread if that is what you mean.
Old 06-29-2015, 10:22 PM   #8
Originally Posted by slimfire View Post
This look like they would work really well I will need to look for them. thanks
Old 06-29-2015, 10:27 PM   #9
How hard do you guys think it would be to make one out if a scrap tube?
Old 06-29-2015, 11:14 PM   #10
...It's not really difficult
If you know the required specifications,
have some experience with tooling
and already have the necessary tools/materials.
^ If you're not confident in your ability
or lack the proper tools...
then IMO yer better off buying them already made.
Accuracy will be critical to insure that the grub screw's
drilled/threaded holes line up properly.
I own all the proper tools...
and still chose to buy rather then fabricate my own.
TacoCrawler is offline   Reply With Quote
Old 06-29-2015, 11:16 PM   #11
I got tools to make stuff like this. So I mite have a go at it thanks guys for the help.
question on scx10 front axle - Similar Threads
Narrowing front Wraith Axle for front of scx10 rusty577 Axial SCX-10 12 02-02-2013 10:30 PM
Front axle question... Ghostrider304 Axial SCX-10 3 11-28-2012 08:30 PM
Front axle question... Ghostrider304 Axial AX-10 Scorpion 2 11-27-2012 06:03 PM
