07-15-2015, 08:49 PM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: So Cal
| ATTN : WRONCHO OWNERS - Help
Just picked up a Trail Honcho and am trying to put my Wraith axles that I had from a previous project under it. I got the rear axle hung in with straight links with the Honcho skid plate/crossmember. . . I thought I'd be able to run it that way because I had the upper and lower links mounted to the frame instead of the skid plate. I flipped the skid plate to put the driveshafts on the same side as the diffs on the Wraith/AR60 axles. As soon as I did that the rear driveshaft made contact with one of the upper links. I tried changing the upper straight links to some bent links that I had and I still had contact issues. . . I really wanted to get away from having to run the Wraith skidplate and links because I don't want to widen the SCX10 frame. . . Is there any way around that?. What have you guys with Wronchos done?. Any help is greatly appreciated. Thanks in advance!!!! Last edited by INFERNAL; 07-15-2015 at 08:52 PM. |
07-15-2015, 10:41 PM | #2 |
| Re: ATTN : WRONCHO OWNERS - Help
Don't search "Wroncho" Pepe... you might find your own answer ie: Wroncho skid question Wroncho Link Help You could always pm that user that replicated yer green monster Wait... coming from a guy that builds kick ass 1:1 rigs !? really ? Lol |
07-16-2015, 12:33 AM | #3 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
what are you putting in those Taco's your Vending
07-16-2015, 01:11 AM | #4 |
| Re: ATTN : WRONCHO OWNERS - Help |
07-16-2015, 01:25 AM | #5 |
| Re: ATTN : WRONCHO OWNERS - Help Last edited by TacoCrawler; 07-16-2015 at 01:30 AM. |
07-19-2015, 05:00 PM | #6 |
Newbie Join Date: Feb 2015 Location: lloydminster
When I built my Power Wagon Conversion, I had the stock wheelbase scx10 power wagon, and what I did was use the wraith vanquish titanium links and curries along with the stock scx10 skid and for me everything pretty much worked out. The wheelbase was great as using the narrower scx10 skid instead of the wraith skid shortens the wheelbase to the longer scx10 length without having to shorten the links used. I also used the scx10 cms from vanquish setup with the panhard link and with some tweaking, I made that work for me as well. Hope this helps. I'm pretty sure that the wheelbase is very close to 12.3" or so.
07-19-2015, 08:04 PM | #7 |
Newbie Join Date: Dec 2014 Location: Canada
The link that contacts the driveshaft you need to make yourself and have it bend over the driveshaft Super simple For mine I used all thread and shrink tube. And it was a very minor bend |
07-20-2015, 02:41 PM | #8 |
Newbie Join Date: Dec 2013 Location: HOLANDO
I used axial 106 mm links in the rear for the lowers..98 mm axial for the front lowers.hot racing fixed length wraith links for all the uppers.i did have to bend the 4 uppers a little by hand...there is a little contact with the driveshaft but it dosent affect how it runs...sv3 with velineon motor..93mm gmade piggybacks...rc4wd boggers ....lots of fun on the trails an in the mud...good luck with the build..love mine |
07-20-2015, 04:14 PM | #9 |
Pebble Pounder Join Date: Aug 2011 Location: gaylord
I used the rc4wd rock krawler wraith extended lenght links and didn't have to bend them at all but the tranny ouputs and diffs are on the same side.
07-20-2015, 06:41 PM | #10 |
Nice....forgot...i did reverse the honcho skid plate so the d.shafts lined up |
07-21-2015, 05:03 PM | #11 |
Pebble Pounder Join Date: Jun 2008 Location: Carmichael
Bpcchassis.com link risers. |
ATTN : WRONCHO OWNERS - Help - Similar Threads | ||||
Wroncho owners...need your help | HCE | Axial SCX-10 | 85 | 10-22-2018 08:50 AM |
Attn: Berg Owners | robvbro81 | EnRoute Berg | 12 | 12-06-2008 11:58 PM |
ATTN Kong owners foam configurations? | crawlmaxx | Tires and Wheels | 5 | 12-14-2004 08:06 AM |
