07-25-2015, 11:16 PM | #1 |
Pebble Pounder Join Date: Dec 2014 Location: bryant
| loose axle shaft need help
I was driving my scx10 and i seen that the front wheels where loose when i turn them buy hand. Is it possible i need a new locker? The factory one is still in there. I have read a little about them but could not find much. I need some help with this.
07-25-2015, 11:30 PM | #2 |
| Re: loose axle shaft need help
it's possible that you broke one or both tabs on the cast locker. cheap pot metal cast construction IMO If that occurs with mine... I'm going with a solid spool. It's also possible the axle shaft's tab end snapped or rounded out the locker's seat. |
07-25-2015, 11:37 PM | #3 |
I don't think they are broke because i just put brand new axle shafts in it not that long ago. I have not had it apart yet but i will have to do that tonight. Is it possible that the 4 screws came out or became loose and that is the problem?
07-26-2015, 04:08 AM | #4 |
Quarry Creeper Join Date: May 2013 Location: Knoxville
Can you twist the front wheels in opposite directions? If you can it's in the locker or an axle shaft. If you can't it's most likely a driveshaft issue. Last time I went crawling I lost a grub screw on a driveshaft which caused only the front tires to get power.
07-26-2015, 08:15 AM | #5 |
Rock Stacker Join Date: Nov 2014 Location: Massachusetts
how loose are we talking? It could just be all the play in everything.
07-26-2015, 08:18 AM | #6 | |
| Re: loose axle shaft need help Quote:
07-26-2015, 08:19 AM | #7 |
| Re: loose axle shaft need help |
07-26-2015, 08:35 AM | #8 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
Take it apart and check. It's a locker or an axle. You won't know till you look.
07-26-2015, 09:00 AM | #9 |
| Re: loose axle shaft need help If you can spin the tires a full rotation forward and backwards without moving the other tire something is broken. If you only can move the tire a portion of a rotation before it affects the other tire it is normal "locker slop". Solution... No slop lockers, I have Holmes hobbies in my rig, locked up F, any grip fab, come to mind to as high quality no slop spools. |
07-26-2015, 09:10 AM | #10 |
ya that's just play if you don't comp I wouldn't worry about it.
07-26-2015, 09:26 AM | #11 |
07-26-2015, 09:30 AM | #12 |
How good are the vanquish lockers?
07-26-2015, 09:32 AM | #13 |
07-26-2015, 10:38 AM | #14 |
I joined the Band! Join Date: Dec 2014 Location: Earth
07-26-2015, 02:20 PM | #15 |
How are Hot racing lockers? Most of the parts I am getting for the truck has been hot racing.
07-26-2015, 02:35 PM | #16 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
I've been running the Hot Racing lockers in a couple of rigs for over a year. They've held up fine under plenty of power (ROC 412 3100s on 3s) and a fair bit of abuse, but they do have more play than some of the others out there (e.g., Locked Up FIs and Holmes lockers). Sent from my iPad using Tapatalk |
07-26-2015, 02:52 PM | #17 | |
07-26-2015, 05:42 PM | #18 |
I took it apart and the ends of the shafts are a little worn. Is this caused buy the locker?
07-26-2015, 06:00 PM | #19 |
there is excessive slop in the stock cast locker... but if the tab is rounding out... then the axle shaft itself is likely not hardened steel. In other words... even if you upgrade to a hardened spool or locker that offer a tighter fitment for the axle shaft's end tang... The axle shaft's tang could continue to round out. Got any pics... it may not be too bad yet !? Lose the stock cast lockers... and get an F1 spool instead. Did you take the differential apart yet and inspect the locker ? |
07-26-2015, 09:26 PM | #20 | |
loose axle shaft need help - Similar Threads | ||||
Transmission output shaft screws loose. | flyboy320 | Axial Wraith | 8 | 04-09-2015 11:04 PM |
Loose long axle shaft (front) | donomite | Axial Wraith | 7 | 11-27-2013 09:42 AM |
Drive Shaft comes loose | NHebayer | Axial AX-10 Scorpion | 9 | 11-01-2012 02:41 AM |
Drive shaft comes loose. | Dirby | Axial AX-10 Scorpion | 20 | 01-25-2009 07:40 PM |
Rear Axel Output Shaft Getting Loose... | I SMOKE ROCKS! | Losi Mini-Rock Crawler | 0 | 01-12-2009 07:40 PM |
