01-03-2016, 05:54 PM | #1 |
Rock Stacker Join Date: May 2014 Location: minot
| Currie F9? Rockjocks? SSD Diamond Axles?
Looking to skip the stock Scx10 axles and want some aftermarket axles on my ground up build. I can't decide between these three Vanquish F9's, Rockjocks, or SSD Diamond Axles. I've never ran any of them so please give me your inputs and experience. And what gears your running what are your set ups.
01-03-2016, 07:26 PM | #2 |
| Re: Currie F9? Rockjocks? SSD Diamond Axles?
Or possibly SSD D60's? Please someone help
02-08-2016, 05:51 AM | #3 |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
I've just installed SSD D60 front and Diamond rear axle myself... will know in a few days how they work, I guess. I have Axial HD overdrive bevel gear in front axle and standard Axial HD bevel gear in rear axle. I haven't run the truck yet, but so far it looks very promising ;) I will keep you posted, if you're still interested.
02-08-2016, 05:54 AM | #4 |
RCC Addict Join Date: Jan 2009 Location: Jacksonville Illinois
I have an ssd yeti rear. If I had to buy one again it'd be vanquish.
02-08-2016, 06:25 AM | #5 |
| Re: Currie F9? Rockjocks? SSD Diamond Axles? |
02-08-2016, 06:30 AM | #6 |
I had to spend another $18 for a delrin piece for in front of the pumpkin because it's a ship anchor. And when they announced they were working on newer better shafts I said it'd be nice if the shaft flats were longer, as in nearly touching in the center when installed. That way you'd have more shaft flat in lockers and even be able to use a VP locker w setscrews. My answer was that their shafts meet the same specs as axials so bugger off we don't care about fitting some other companies part... Well. Ok then.
02-08-2016, 06:50 AM | #7 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
I have no problem saying SSD is a great company!
02-08-2016, 09:15 AM | #8 |
Pebble Pounder Join Date: Jul 2015 Location: Fort Collins
I ordered up curries last week. The front showed up and I got it all put together. I am petty impressed with the fit and finish of them. I went wraith width though so I know that won't help much on your scaler. I guess it depends on what body you run. If you are going Jeep style body I would say currie for the scale factor, if its any kind of yota body go SSD because they look just like the 1:1 diamond axles that yota guys love. If you are going ultra 4ish inspired go F9. I think the F9 is only a rear axle though I could be wrong. I don't think you could go wrong any way you go.
02-08-2016, 03:03 PM | #9 |
SSD is a good company. Just soured me a bit to not care for my input.
02-08-2016, 04:25 PM | #10 |
I think it all boils down to personal preference, decide what you like the look of and go with it. If you don't like it you can usually post it up for sale or trade in the classified and work towards something that suits your needs a little better, I think every company has their advantages and drawbacks, it can a challenge to design a product that is going to work for every person in every build in every situation. Best of luck on the build
02-08-2016, 04:31 PM | #11 |
Pebble Pounder Join Date: Apr 2013 Location: SoCal
I just installed the boomRacing Phat axles. They are a direct replica of the stock scx10 housing. I have two runs on them no problems so far, they are 180 grams a piece.
02-08-2016, 04:45 PM | #12 |
02-08-2016, 04:59 PM | #13 |
Quarry Creeper Join Date: Dec 2015 Location: San Diego
I. Running SSD D60's with OD front gears and UD rear. So far I like them. I did however have to use ad dremel on them to get my Vanquish C-hubs and lockouts to fit properly. |
02-08-2016, 05:34 PM | #14 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
A friend of mine broke the 3 link mount on his ssd d60 axles twice this weekend. He will be buying curries.
02-09-2016, 09:16 AM | #15 |
I would avoid the F9 for a crawler build. It has no option for a skid and will get hung up everywhere. Any of the other choices on your list are a great option.
02-09-2016, 09:45 AM | #16 | |
| Re: Currie F9? Rockjocks? SSD Diamond Axles? Quote:
The rockjocks are much rounder then the F9's though. | |
02-09-2016, 10:05 AM | #17 | |
02-09-2016, 10:19 AM | #18 | |
Here is a good example of our rock, ignore the broken berg... | |
02-09-2016, 11:24 AM | #19 |
oh ok that explains a lot then. In Colorado we have nice high traction sand stone and slick rock, nothing quite that nasty. My tires last forever out here. I was starting to worry about the skids ripping off but I think given the rocks you play in I should be ok. thanks for the info!
02-09-2016, 07:00 PM | #20 |
Newbie Join Date: Jun 2014 Location: Mt juliet
I would go VP Curries FTW! Although the new F9's are sweet, curries are just plain awesome! They can take a good beating on the tubes also and not look as bad as it sounds most of the time.
Currie F9? Rockjocks? SSD Diamond Axles? - Similar Threads | ||||
Rear SSD Diamond Offset issues | Beorn | Axial Wraith | 22 | 10-25-2015 11:19 PM |
NorCal's Wraith on VP/Currie RockJocks | NorCal 2500HD | Axial Wraith | 66 | 09-10-2015 07:35 PM |
Ssd diamond centered wraith axle | VelineonSlash | Newbie General | 5 | 07-23-2015 08:11 PM |
