03-29-2016, 07:56 AM | #1 |
Rock Stacker Join Date: Mar 2016 Location: Austin
| scx10 deadbolt front diff squeak??
I have a fairly new scx10 deadbolt with the stock motor. I hear squeak from the front suspension. Is that normal? I disconnected the front center driveshaft and I see that the wheels dont roll as smoothly as the rears do. There is probably some binding inside the diff case. Anyone experienced it before and any suggestions on the fix? I did order Axial CVD's so that I can get better steering angle. Not sure if that will fix any of this. UPDATE (Found the problem): I opened up my front axle and what is see is that the ring gear (large) is sat firmly between the bearings. But its the pinion gear that has play in it. So when the center drive shaft accelerates or decelerates, the play makes the pinion gear move back and forth on the ring gear causing it to lock up against the diff surface. I held the pinion gear out as much as possible and then rolled the wheels and the Vola.... no more resistance. I need to find some good 6mm washers and put them between the center drive shaft and the pinion gear to make sure the pinion gear is not pushed deep. Although I wonder why the rear diff is not seeing this issue. Last edited by metblack328i; 03-29-2016 at 10:51 PM. Reason: Found the problem. |
03-29-2016, 08:10 AM | #2 |
RCC Addict Join Date: Apr 2009 Location: LA
| Re: scx10 deadbolt front diff squeak??
Sorry, I'm unclear. Is the squeak/issue with the shocks/suspension when you move it up and down, or with the driveline when the wheels roll/turn?
03-29-2016, 08:27 AM | #3 |
Newbie Join Date: Feb 2015 Location: Portsmouth
I have the same problem with my deadbolt, the front axle doesn't roll smooth like the back one. I'm going to pull it apart and check it out, if no one posts up an answer for it.
03-29-2016, 09:35 AM | #4 |
Quarry Creeper Join Date: Jul 2014 Location: saranac
Check the bearings.
03-29-2016, 09:43 AM | #5 | |
| Re: scx10 deadbolt front diff squeak?? Quote:
When I disconnected the center drive shaft and roll the wheels, I can see that there is some resistance from the diff's. When I roll them a little fast, I hear the squeak. | |
03-29-2016, 09:45 AM | #6 |
| Re: scx10 deadbolt front diff squeak?? |
03-29-2016, 09:46 AM | #7 |
03-29-2016, 10:42 AM | #8 |
I've never met an SCX10 that didn't squeak after just a few runs. Your driveshafts might also be the culprit. |
03-29-2016, 10:56 AM | #9 |
| Re: scx10 deadbolt front diff squeak?? you mean the center driveshaft (from the center differential to the axle itself) or the Axle shaft (from the wheel to the center diff)? The former one is pretty smooth in my case. thats why I disconnect the center driveshaft and rolled it.
03-29-2016, 10:59 AM | #10 |
this is what my diff is doing even with the axles removed so i think i need to shim the diff Last edited by lukejr77; 03-31-2016 at 03:15 PM. |
03-29-2016, 11:06 AM | #11 |
Yes... yes you do.
03-29-2016, 11:23 AM | #12 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
I'm interested in this topic
03-29-2016, 12:17 PM | #13 | |
I use black grease during assembly. When that's gone I use silicone grease until I rebuild them at which time I use black grease again. WD-40 Silicone Grease: Silicone Lubricant & Silicone Grease - WD-40 Specialist | |
03-29-2016, 12:29 PM | #14 | |
03-29-2016, 12:31 PM | #15 |
Does anyone know if there are dust covers available for the center drive shaft joints? That can help us keep the grease in-place.
03-29-2016, 02:54 PM | #16 |
Quarry Creeper Join Date: Mar 2016 Location: juneau
Lube up your drivelines and components. NAPA silo glide works good
03-29-2016, 03:20 PM | #17 |
Rock Stacker Join Date: Feb 2016 Location: Ft Myers
When I first got mine it squeaked a lot. I sprayed a little WD40 and it stopped completely. I know the WD40 won't last, I'll try a little grease if it starts again but I know it's the driveshaft joints now.
03-29-2016, 03:52 PM | #18 | |
These are from traxxas e revo drive shaft boots. Just ordered 2 pairs from tower. | |
03-29-2016, 09:02 PM | #19 |
Have you tried molybdenum lube it lasts longer than some of the other stuff I've tried. Or dry silicone spray so you don't attract dirt sand etc
03-29-2016, 09:52 PM | #20 |
If you're talking about the connection between the dog bone and this part: then it's called the output shaft or drive cup. The driveshafts, on the other hand, connect the tranny to the diff. Just trying to keep things clear. ;)
scx10 deadbolt front diff squeak?? - Similar Threads | ||||
AX10 deadbolt body on SCX10 deadbolt | BrianP | Axial SCX-10 | 3 | 11-08-2015 04:51 PM |
NEW SSD Front bumper for SCX10 Deadbolt or G6 Jeep | RPP Hobby | RPP Hobby | 0 | 06-11-2015 11:22 AM |
Scx10 Open Front Diff? | BigChevyTruckin | 1.9 Scale Rigs | 42 | 05-14-2015 01:03 AM |
Scx10 front diff help | JParr90 | Axial SCX-10 | 9 | 03-02-2014 03:06 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
