08-08-2016, 04:09 AM | #1 |
Newbie Join Date: Jun 2016 Location: Bucharest
| Advice for choosing a new body
Hello, I'm trying to find a replacement body for the stock Power Ram SCX10 body. I'm looking for something as scale as possible (headlights, taillights, complete interior, exterior details - mirrors, wipers, front grills, etc), that would accommodate the new SCX10 II tires (link) which are bigger than the stock Ripsaws. What body should I choose that would fit the new bigger tires, without chopping it? I would prefer keeping the ~313 mm wheelbase I currently have. For example, will the RC4WD Chevy Blazer hard body (link) accommodate the bigger Axial 1.9 BFGoodrich tires? Here is how the current body sits with the new, bigger wheels: SCX10 II BFGoodrich tires - Imgur Thanks! |
08-08-2016, 01:31 PM | #2 |
RCC Addict Join Date: Jan 2007 Location: Arkansas
| Re: Advice for choosing a new body
You would have to do some cutting on the RC4WD body to get those tires to clear. Mounting that body will also take some work but that shouldn't be too hard. Due to the drop bed, you will either have to cut holes in the bed for the shock hoops, or use an inboard shock kit (or fab up your own). |
08-08-2016, 02:44 PM | #3 |
Newbie Join Date: Apr 2011 Location: Surrey, BC
If I am not mistaken the rc4wd blazer body is an 11.3" wheel base and your chassis is a 12.3".
08-08-2016, 03:16 PM | #4 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
I love this place everyone's so exact. Saves a lot of money on potentially expensive mistakes to those of us who can't fabricate stuff etc. Always best to ask questions, I've made so many mistakes !!!!
08-10-2016, 02:42 AM | #5 | |
| Re: Advice for choosing a new body Quote:
I butchered the power ram body already, i don't want to butcher an expensive one (like the rc4wd chevy), because I'm sure that, knowing my skill set (and tools), the end result wouldn't be a good one - link What are my other body options, that would clear those tires and have a scale look? I'm trying to find out the wheel wells dimensions for this cherokee body (link). It seems that it would fit better than the rc4wd ones. The problem with it is that it doesn't have an interior... | |
08-10-2016, 02:45 AM | #6 |
| Re: Advice for choosing a new body I made the current 12.3" links myself using the traxxas rods and threaded bars, so I could build other (although I don't know the links widths needed for a 11.3" wheelbase... )
08-10-2016, 02:51 AM | #7 |
| Re: Advice for choosing a new body I think the fabrication part can be handled in most cases, the "what to fabricate" is the problem.
08-10-2016, 08:49 AM | #8 |
Yeah the Ram body is pretty small and has to be hacked quite a bit to clear larger tires. I'm planning on another build with that body but its going to use small tires. The EASIEST way would be the Axial Jeep Unlimited body and roll cage. It will clear the tires and there are aftermarket 3D printed parts available such as door handles, door hinges, wipers, grilles, etc. There are more detailed hard bodies (such as New Bright 4 door Jeep or the China XJ) out there, but they are going to require you to at a minimum figure out a mount for the body. That can be as simple as a bent piece of scrap aluminum and Velcro. Some of them may also require front mounted motors, relocating shocks, etc if you are wanting to run a full interior. Skim through the picture threads and find a body you like then search on here for that body for more details. There are tons of skilled builders on here to get ideas from. |
08-10-2016, 10:56 AM | #9 | |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
Although it's been done, done, and done again, the Unlimited body kit really is a great base for a scale lexan body. You can keep it simple or go all out with scale detail, and it'll generally be more durable than styrene. I hope they won't discontinue that kit anytime soon, because I could see myself getting another one, some day. | |
08-10-2016, 11:27 AM | #10 |
Look at what I found on the axial website: Axial Racing - 2000 Jeep® Cherokee Body - .040" (Clear) - Complete I'm definitely getting one of those. Meanwhile, I'm going to check out this body to see if it fits my scx: new bright jeep. |
Advice for choosing a new body - Similar Threads | ||||
Dilemma in choosing types of axles, advice please. | novaris | Newbie General | 2 | 10-14-2015 10:05 PM |
choosing a body | Sethhh | Paint and Body | 0 | 03-27-2013 07:22 PM |
Need advice choosing ESC for Honcho | yellorover | Axial SCX-10 | 20 | 01-01-2010 03:36 PM |
advice for choosing a first crwaler | dirtymike | Newbie General | 11 | 09-07-2009 06:41 PM |
Newbie seeking advice on choosing tires for Wheely King to make it more realistic | painter4x4 | Newbie General | 13 | 06-14-2008 09:10 PM |
