Thread: STRC rear lockouts fitment issue
Old 07-15-2014, 08:49 PM   #1
Default STRC rear lockouts fitment issue
Hey guys. I know STRC stuff is questionable at times, with now being one of those times.
I put the rear lockouts on my G6 and there is a good 1/4 inch of play in the rear axle output shafts. Am I missing something here? Looking inside the STRC lockouts, it almost looks like they will accept a bigger bearing further in.
Any ideas here?
1967Typhoon is offline   Reply With Quote
Old 07-16-2014, 01:18 AM   #2
Default Re: STRC rear lockouts fitment issue
Any ideas here?
I use strc rear lockouts and dont see how it would be possible for you to have any play. Could you be more specific, maybe some pics?
(I am using Strc axles but not sure how that would make a difference.)
rcwolf is offline   Reply With Quote
Old 07-16-2014, 01:36 AM   #3
wait.. where do you have your bearing? It is on the axle right behind where the hole for the pin is so it actually sits just inside the outer (narrow) end of the lock out right?
Old 07-16-2014, 06:52 AM   #4
There is a gap between where the bearing sits and the end of the lockout. This allows the shaft to move in and out. I ended up finding 2 nylon washers the same diameter as the bearing and put them in between the bearing and the end of the lockout. This actually worked really well, but I don't feel I should have to dig through my hardware to make something like that work.
I poked around and found a couple of other people with the same issue.
Old 07-16-2014, 07:03 AM   #5
Most axles could use shimming here and there. It's normal - bearings, shafts, gears all wear or have separate tolerances.
Get a shaft with tolerances to the far left and bearing to the far right along with not perfect lockouts - wiggle wiggle.
doublej is offline   Reply With Quote
Old 07-16-2014, 08:46 AM   #6
Originally Posted by doublej View Post
wiggle wiggle.
Shim shim
Postclanker is online now   Reply With Quote
Old 07-16-2014, 08:54 AM   #7
That's weird cause I didn't have issue's mounting STRC lockouts on my jeep Unlimited. Maybe they were cut wrong from the factory, that's all I can think of but I'd doubt that cause STRC quality isn't that bad.
axial 4x4 crawler is offline   Reply With Quote
Old 07-08-2016, 11:16 PM   #8
i just installed some strc lockouts and have the same 1/4" of play. too late to find a fix tonight. going to tackle it in the morning.
fishrocks17 is offline   Reply With Quote
Old 08-28-2016, 09:26 PM   #9
Having the same issue myself, anyone figure out why?
BlownChevelle is offline   Reply With Quote
Old 08-28-2016, 11:08 PM   #10
Where do you shim? Having this issue myself, cost me and end link already.
seal20 is offline   Reply With Quote
Old 08-29-2016, 06:43 AM   #11
In the ends of the axle between the bearing and the end of the lockout. If you look, you can see the gap there. That gap needs to disappear with washers. But you cant just throw any washer in there, it needs to clear the center of the bearing, otherwise there will be binding.
I would post pics but I sold that rig long ago.
Old 08-29-2016, 07:52 AM   #12
Covered in the yeti section, cut a shim from old axle and insert in between the shafts.... 3.5 to 4mm works well
HANG UP AND DRIVE !
mikemcE is offline   Reply With Quote
Old 09-08-2016, 10:06 AM   #13
Yup, sounds normal, I have a bit of play in one of my Vanquish lockouts, not that much tho. Shim that mofo
FrancoSFL is offline   Reply With Quote
Old 09-08-2016, 08:25 PM   #14
I just did rear lockouts and found the same problem. I went back to the shop and the guys gave me some mini washers to soak up the wiggle. They said its normal but doesn't change performance. wiggle-wiggle-wiggle gone....
gonzo532 is offline   Reply With Quote
STRC rear lockouts fitment issue - Similar Threads
FYI- Golden Horizon beats STRC on fitment it8ezbngrn Axial Wraith 0 06-03-2013 01:00 AM
STRC fittment issue Rook82 Axial Wraith 12 10-12-2012 03:57 PM
Strc lockouts adamargue HPI Wheely King 2 11-11-2010 08:39 PM
strc rear lockouts LEROY Axial AX-10 Scorpion 11 01-09-2009 05:19 AM
STRC or AXIAL LOCKOUTS aljeann Axial AX-10 Scorpion 4 06-29-2008 09:50 PM
