09-12-2016, 02:32 AM | #1 |
Newbie Join Date: Jun 2016 Location: Bucharest
| Front axle angled down causes torque twist?
Hello, I've having some problems with my SCX10. Initially i've created some diy links for the power ram body (~12.3 wheelbase), 4 link front, everything worked ok. In order to mount the new bright jeep body I had to extend the wheelbase. To do that, i've modified only the upper front links and now the front axle is tipped down. I also added the rc4wd 100mm king shocks. The problem i'm having is that the left drivers side tips left when accelerating, even a little. Is this caused because of the wrong axle angle or is it because of the softer shocks (i've set them up so that the whole body comes down ~1 - 1.5 cm when left on it's weight). I've tried stiffening the front left shock without almost any effect... The whole truck weights around 8 lb. Any ideas on what I should do to fix that? I'm going to post some pics and video when I get home to better explain my problem. Thanks for the help!!! |
09-12-2016, 02:52 AM | #2 |
| Re: Front axle angled down causes torque twist?
For starters, lengthen the lowers to get the axle back to the proper angle...you should have lengthened the uppers and lowers by the same amount...possibly doing the rear only or splitting the total length equally between front and rear....
09-12-2016, 03:10 AM | #3 | |
| Re: Front axle angled down causes torque twist? Quote:
The optimal solution is to have the front links length equal to the respective rear links, right? Let's hope the traxxas rod ends threads hold another modification Thanks | |
09-12-2016, 05:24 AM | #4 |
Newbie Join Date: Sep 2016 Location: kansas city
From what ive seen on the different stock scx10 models. The rear is where all of the length adjustment is done. When i bought my aluminum parts i had to find the correct length for the rear but the front were all the same length.
09-12-2016, 08:42 AM | #5 |
the easiest thing would have been to lengthen the lowers first, but i usually get the fronts set where they need to be while making sure the servo isnt pushed too far forward and hitting the crossmember, then I set the rear where it needs to be. very seldom is the front and rear lengths the same... a few pics would help alot to see whats going on...
09-12-2016, 08:44 AM | #6 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
| Re: Front axle angled down causes torque twist? Yup, usually you want to tinker with the rear axle to get the length you need. If you were shortening it greatly I could see you doing the front and the rear. But shortening the front only probably isn't the best route. As far as it adding torque twist, that part doesn't make much since. Are you SURE it didn't have torque twist before? The only solid mods I know of to remove torque twist are to mirror the transmission, or try to tune it out somewhat with suspension setup.
09-12-2016, 09:05 AM | #7 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
The torque twist may have just become more obvious with the new shocks you added. This is why I prefer to only make one change to my truck at a time, it allows more opportunity to diagnose oddities.
09-13-2016, 08:33 AM | #8 |
Here are some images/videos with my setup and problem: Video 1: https://youtu.be/h_zwiEiRCSQ https://youtu.be/tZedtLNpGw8 Video 2: (drive shafts chatter?) https://youtu.be/eHhuxfQ-bHU Front axle side view: Front axle frontal view: Front left shock setup: Front right shock setup: Rear shocks setup: Rear lower links: ~13.5 cm - including the rod ends Front lower links: ~13.8 cm - including the rod ends Lateral view: Last edited by devuser; 09-13-2016 at 08:34 AM. Reason: images path |
09-13-2016, 10:36 AM | #9 |
RE: Video 1 That's just torque twist, almost every SCX I've seen does that to some extent. You can mirror the tranny to get rid of most of it, or if you increase the preload on the left rear shock that should help. I don't like mirrored tranny's because you have to delete the spur gear cover. It looks more obvious because of your soft shocks but it's not specifically hindering performance - it just looks ugly. I'm not sure if that axle rotation is a problem or not; it probably is. The pinion angle is good by having it rotated that way, but if you don't clock the C hubs it also alters your steering geometry. RE: Video 2 Looks like maybe your driveshafts are out of phase. Did you align the little marks when you assembled them? |
09-13-2016, 10:39 AM | #10 | |
09-13-2016, 11:02 AM | #11 |
You probably raised the roll center by adding a heavier body on top. Test this by removing the body and seeing if the twist goes away. You will need to raise your upper links on both axle and chassis to get the roll center back to your CG. This will screw with your antisquat, it might cause more problems than it solves. Alternatively, add weight very low to your chassis (skidplate height) and this will lower your CG towards the roll center. Since the body is further away from the roll center than the skidplate, you will need to add more than the body weight to counterbalance. Anything will help, but you will probably need 2 to 3 times the body weight to negate the twist it causes. |
09-14-2016, 05:55 AM | #12 | |
Caster angle - i've just read some things I'm going to create new links for the front so that the axle has the initial RTR angle which should be perpendicular on the ground and not tilted forward as it currently is.. | |
09-14-2016, 06:07 AM | #13 | |
Haven't weighed the body yet but I think it has around 0.5 kg. the whole truck has ~3.5 - 4 kg. From reading your post and looking at the truck it seems indeed that the body it very up high and combined with it's weight and bad links sizing, it's causing that ugly left tip... I'm going to recreate all upper/lower links, equal sizes for front and back to fit the new bright body wheelbase and correct axle position. Would it help if I add a shock lowering kit? The stock shocks were ~90mm and the rc4wd ones are 100mm. | |
Front axle angled down causes torque twist? - Similar Threads | ||||
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
No-torque-twist solid axle | fyrstormer | General Crawlers | 11 | 05-10-2016 04:17 PM |
front xr10 axle has no torque | jbailey2478 | Axial XR10 | 16 | 04-15-2012 04:34 PM |
right front tire lift(torque twist) | rockerrc | Axial AX-10 Scorpion | 9 | 12-20-2009 08:39 PM |
Cheap mod for axle steer/torque twist | Oze30 | Axial AX-10 Scorpion | 5 | 03-03-2008 05:28 PM |
