12-29-2016, 04:49 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Play in rear axle, is this normal?
I just put new bearings in my rear axles and I noticed once I got them together there's play in and out. Check out my video below and see if this amount of play is normal or anything to worry about I did make sure I put the axles in all the way and turn to make sure they was all the way in. https://youtu.be/twmz3nkvG84 |
12-30-2016, 01:53 AM | #2 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: Play in rear axle, is this normal?
Nope that's not normal. And tbh I'm a bit lost to what it could be.
12-30-2016, 02:29 AM | #3 |
RCC Addict Join Date: Oct 2014 Location: UK
missing bearings in the lockouts, or maybe bad lockouts.
12-30-2016, 05:25 AM | #4 |
Well, I had my stock lockouts on before I tore them down, when I put them back together i used STRC aluminum lockouts that I had laying around (got them in a trade). But I will take everything back apart and put my stock lockouts back on and see if the play goes away. Stay posted...
12-30-2016, 07:38 AM | #5 |
Had that in my Yeti after installing beef tubes . They require grinding a bearing lip, I shimmed the axle with a small piece of an old shaft.... pic in the yeti area Hang up and Drive |
12-30-2016, 11:54 AM | #6 |
The STRC aluminum lockouts was the culprit. It's hard to tell in the pic, but the outer "lip" so to speak on the STRC lockouts is maybe 1.5mm thinner than my stock, thus allowing the bearing to slide in and out. Probably wouldn't have hurt anything, but I just put the stock back on, realized I didn't like the aluminum look on those anyway. |
12-30-2016, 01:15 PM | #7 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
You could probably put a washer/shim in there to make up that difference to make it work.
12-30-2016, 07:01 PM | #8 |
Yea I'm sure I could have, but I like the looks of the stock black plastic one better anyway
12-31-2016, 02:15 AM | #9 |
If you want good fitting lockouts: Rear Lockouts for SCX10 / D60 Axle |
01-02-2017, 05:17 PM | #10 | |
Pebble Pounder Join Date: Mar 2016 Location: Mountains
| Re: Play in rear axle, is this normal? Quote:
01-02-2017, 05:41 PM | #11 |
Didn't the rear axleshafts used to come with shims for this? Place shims behind the rear wheelbearings to snug it up. I've also had the issue of the shafts "falling" into the housing after grinding the inner lip off to fit through beef tubes. In that case I either run a felsenfest clamping spool, or make a small steel spacer to hide inside the spool to keep the axles at the proper spacing. |
01-03-2017, 02:32 AM | #12 |
| Re: Play in rear axle, is this normal? |
Play in rear axle, is this normal? - Similar Threads | ||||
play in rear scx10 axle? | Tfree2014 | Axial SCX-10 | 8 | 11-30-2015 10:48 AM |
rear axle play | ncampos976 | EnRoute Berg | 4 | 06-23-2013 02:57 PM |
Rear axle play? | (Greg) | Axial XR10 | 10 | 03-27-2011 03:49 PM |
Replacing rear steer with normal straight axle | scoobydann | Newbie General | 6 | 05-04-2010 11:53 AM |
Slight play in rear axle | procraft98 | Newbie General | 10 | 09-20-2007 08:19 PM |
