Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Negative camber
Old 09-06-2016, 12:26 AM   #1
Default Negative camber
Does anyone have a few degrees of negative camber in their front axle? I can't see where I assembled my kit incorrectly, but it doesn't seem correct. The rear is fine.
It's hard to capture on camera, so I won't bother posting a picture.
robertjpjr is offline   Reply With Quote
Old 09-06-2016, 06:03 AM   #2
Default Re: Negative camber
This is from Axial's website;
"KINGPIN ANGLE
The AR44 axle was designed for both aesthetics and functionality. To improve upon the older AX10 axle, we designed the steering components with an 8 degree kingpin angle which results in a positive scrub radius. Making this change to the pivot point means less tire scrub for steering efficiency and less load on the steering servo."
• 8 degree kingpin angle
• Improved scrub radius over the AX10 axle
Web page;
Axial Racing - SCX10 II
~D
Say what? is offline   Reply With Quote
Old 09-06-2016, 07:18 AM   #3
Are you referring to "pinion angle" as in the link length might be incorrect?
skybolt is offline   Reply With Quote
Old 09-06-2016, 09:24 AM   #4
I see some on my RTR.
Ro@dkill is offline   Reply With Quote
Old 09-06-2016, 10:00 AM   #5
This is obviously a bit dramatic, but this is what I am referring to.
I overlooked the Kingpin angle clocking in the manual. It seemed like a fixed position which led me to think it was normal. But its different from the SCX10.1 so I was just curious.
Thanks for the link "Say What?"
This is what the googles pulls up on the matter..
Old 09-06-2016, 10:02 AM   #6
I have a couple trucks with some slight negative camber. I know mine is caused by slop in the knuckles and stub shafts. I finally got around to getting shims to take out most of the slop but I've been too lazy to install them.
SCREAMER is offline   Reply With Quote
Old 09-06-2016, 10:07 AM   #7
OOHHHH.... you're referring to "CAMBER"
the comment about the rear being fine confused me...
NO. I have no camber, neg or pos, when the wheel's are pointed dead ahead.
Old 09-06-2016, 12:04 PM   #8
There's no camber built in/intended. I do find though that the plastic wheels and other plastic steering components introduce a bit of slop giving it some camber if most of the weight is on the front wheel or rolling over a round object. Tolerances just aren't that small on the stock setup.
Here's a picture of mine which shows this (it's looking worse than it is due to the angles / close-up photo).
IVIaarten is offline   Reply With Quote
Old 09-06-2016, 12:54 PM   #9
I was looking at mine the other day and noticed it had the same problem. I also noticed when I picked it up and started really looking at it. I noticed that the lower portion of the stock C hubs are actually slightly stressing or bending in an upward angle. Inducing a lot of negative camber. The lower portion is nearly riding on the universals as they rotate. I see an upgrade to an aluminum C hub set in my near future.
luckster is offline   Reply With Quote
Old 10-02-2022, 04:44 AM   #10
I have negative camber in a freshly built kit. Thought I messed up the assembly but everything seems in place. It is normal?
cooper_xl is offline   Reply With Quote
Old 10-02-2022, 06:19 AM   #11
If you have straight axles then no its not normal. Independent suspension is a different animal though.
themountain is offline   Reply With Quote
Old 10-02-2022, 07:26 AM   #12
What kit?
If you installed the C hubs incorrectly, you will have negative camber.
lonleycreeper is offline   Reply With Quote
Old 10-02-2022, 05:14 PM   #13
Originally Posted by lonleycreeper View Post
What kit?
I have the kit that came with the older style of axles:
Knuckles are impossible to get wrong, because of the panhard mount. C-hubs,apart from being clocked wrong, are correct. The no1 on the right, no2 on the left. Can't figure out what's wrong.I'm getting 4º of camber on each side
Old 10-03-2022, 01:25 AM   #14
With a straight axle its impossible to have that amount of camber...maybe something is wrong with your wheels
Old 10-03-2022, 03:13 AM   #15
I agree with Mountain about the wheels, but I'm also perplexed as to why you're worried about such a minute amount of camber.
Goos3 is offline   Reply With Quote
Old 10-03-2022, 09:23 AM   #16
just a tiny amount of slop anywere in the setup translates to alot of slop at the wheel
some comapnys will adjust for this slop but its almost imposable to get it 100% every rig is different
and besides who cares its a toy truck your tires wont ware funny theres no vibration and your not going fast enuff for any of it to matter anyway
ferp420 is offline   Reply With Quote
Old 10-03-2022, 05:05 PM   #17
4º doesn't seem much but it's pretty noticeable. There's a 7,5mm difference at the top of the tire. I just would like to know the cause. Is a brand new kit
Old 10-03-2022, 06:47 PM   #18
Without seeing pictures of the actual issue people can only speculate.
bgredjeep is offline   Reply With Quote
Old 10-04-2022, 06:10 PM   #19
I did not post any pic because it is hard to photograph
Old 10-04-2022, 08:29 PM   #20
You guys sure you're not talking about Caster vs Camber? All these crawlers have 0°of camber. Otherwise the tires would be at a slant. If you're talking the kingpins being at an angle, that's intended.
Gula is offline   Reply With Quote
Negative camber - Similar Threads
Negative Camber with stock settings amped up Axial Yeti 9 11-19-2015 05:00 PM
Installed asiatees c hubs, now my camber is negative? woodsman541 Newbie General 18 03-13-2015 07:17 AM
Rear negative camber? frdtrkguy General Crawlers 1 12-30-2007 09:30 AM
negative ground systems? slugzracing Electronics 3 05-24-2005 06:32 PM
