Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial SCX10 II
Thread: Scx10 II = Wow! (Plus SSD DIY hex bolt tool)
Old 08-20-2016, 05:44 PM   #1
Default Scx10 II = Wow! (Plus SSD DIY hex bolt tool)
So I picked up a new II so I could accompany my son with the scx10 v1. I put some Pitbull Growlers & SSD D Hole stamped beadlocks on and pushed the front and rear bumpers in a bit for better approach angle, that's it. I'm super impressed! Even the electronics mated to this chassis are great running 3s. Torque is good, steering is usable. I'll definitely be on the lookout for some OD gears for the front axle, knuckles to provide a little more steering, and I'll be putting in a better servo and HH 35t handwound I have lying around. I'm just so impressed right out of the box! It doesn't roll in situations where the scx10 v1 always does and I just made a climb that I couldn't make with the bomber wearing 2.2 Rock Beast II rubber.
I finally love a 1.9 rig!!
So stable and so fun!
My one gripe is that the wheelbase looks about 1/4" too short for the body. It also would have been nice if The door handles had come installed. :-).
on a side note: I didn't know to order the tool for the hex bolts on the SSD wheels but I'm glad I didn't! After a quick search it seems people have had nothing but problems with the bolts heads rounding when trying to tighten.
1) After another search I picked through my bowl of m3 screws, found one that fit nice and snug, applied a little red loctite on and around the outside of a nylon lock nut and inserted it into an extra axial "t" wrench.
Result..... The perfect m2 hex bold driver!
I loosened all the bolts half way, added some loctite, tightened everything down snug. No drama, no rounded bolts.
Irishchamp is offline   Reply With Quote
Old 08-31-2016, 11:50 PM   #2
Default Re: Scx10 II = Wow! (Plus SSD DIY hex bolt tool)
Them rims look super cool on that rig....
1beatjeep is online now   Reply With Quote
Old 09-05-2016, 10:26 AM   #3
Ok, so I got a little carried away last night on RPP, not everything ordered is for this rig but I definitely have a few nice additions coming........
Old 09-05-2016, 12:24 PM   #4
Originally Posted by IVIaarten View Post
looking forwards to what you're going to do with it.
Old 09-05-2016, 12:25 PM   #5
Originally Posted by Irishchamp View Post
Guess that means it's either going to be great, or it's going to go up in flames...
IVIaarten is offline   Reply With Quote
Old 09-05-2016, 12:40 PM   #6
Lol, I suppose so.... I'm hoping for option one!
Old 09-19-2016, 09:28 PM   #7
These showed up in the mail today...........
Old 09-19-2016, 09:40 PM   #8
I give up what are them beside axle housing
Old 09-20-2016, 09:13 AM   #9
American Machine Works Ohio brass axle tubes.
Old 09-20-2016, 10:36 AM   #10
That's a damn clever idea for the 2mm wrench!!
QuesoDelDiablo is offline   Reply With Quote
Old 09-20-2016, 10:52 AM   #11
Balance Port...How many cells do you count?
That spur looks larger than the cover, how many teeth does the thing have?.... Did you know that in Scale RC Stubby is sexy!?
Thats Purdy!
Old 09-20-2016, 11:09 AM   #12
Thank you both, I've replaced the socket head screw once, swapped to a button head, its been perfect, not stripping a single head on 3 sets of wheels.
Originally Posted by M J View Post
Yes - great idea. I was just pondering over this last night!
Old 09-21-2016, 11:13 AM   #13
I got all the electronics wired up yesterday, I didn't post a pic but I'm running a Holmes BLE Pro esc. geared 64/9.
It's stuttering under load at low speeds. I've tried all different start power settings, timing 0-10, SMART SENSE, sensored only, and 13-24 frequently. There are two things that make a slight improvement, lower voltage battery (3s), and lower frequency (13). I've tried 4s and 6s lipos, stuttering increases slightly with each voltage increase. I've also swapped sensor cables, no change. I unplugged the sensor cable, motor then cogged rather than stuttering.
Hoping to hear back from Holmes Hobbies on this ASAP.
In the limited driving I did I'm quickly coming to the conclusion that the RC4WD Falken Wildpeak tires are garbage! lol. Well thats a little harsh, they're garbage in loose dirt, that was to be expected though. I just wanted to try a taller 1.9 tire, these are 4.82" tall. I'm going to give them a little more time, I highly doubt they'll be my go to tire but might work for something, haven't figured out what that "something" is yet....
Old 09-21-2016, 12:41 PM   #14
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Maybe post a vid of the studdering? It could be a grub screw catching, or you might just be noticing the most subtle startup hesitation with our firmware.
JohnRobHolmes is offline   Reply With Quote
Old 09-21-2016, 01:58 PM   #15
I'll get a video this evening. I'll also check the drivetrain for binding/catching.
Old 09-21-2016, 05:58 PM   #16
Very difficult to capture, this is the best I was able to get. the stuttering is not at the slowest throttle input, it's right past minimum throttle input. I have another BLE Pro NIP, I'm going to try that next....
EDIT: it also seems to stutter some when rolling downhill using drag brake.
Old 09-21-2016, 09:12 PM   #17
Ok, so I am an unhappy camper! SHV500 servo had a glitch fit and died, took my receiver with it. I've tried two esc's, two Rx's and no solution found, plus a brand new servo dead along with a receiver.
Could it have been the servo? That seems unlikely, I tried with the servo unhooked previously....
Could the motor have a bad sensor board? Could a bad sensor board in the motor create interference causing the servo and Esc to glitch? Could interfere cause a servo to fail?
Old 09-21-2016, 10:05 PM   #18
Pro4/MMP comparison.
Old 09-21-2016, 10:55 PM   #19
No real input on the issue, however what rear bumper is that. Do you have photo's of it with the body on?
gigacrawl is offline   Reply With Quote
Old 09-22-2016, 06:46 AM   #20
Patience...... :-) Patience, all your questions will be answered.
I'll have to check and see if I have a part # for the bumper, I will also post some pictures of the truck with the body installed in the near future.
Scx10 II = Wow! (Plus SSD DIY hex bolt tool) - Similar Threads
DIY fuel injector pulse tool BigSki Tools, and Procedures 12 08-02-2016 09:45 AM
Scale bolt tool Turtlejon Tires and Wheels 5 12-22-2014 12:52 AM
rc4wd scale hex bolt tool HELP discgolferlee Tools, and Procedures 20 06-15-2013 07:26 PM
