09-18-2016, 07:56 AM | #1 |
Newbie Join Date: Jul 2016 Location: UK
| Wheelbase Adjustment on the SCX10 II
What's the best way to adjust the wheelbase on the SCX10 II? This is my first kit so I don't have any experience with this. How would I go about reducing the wheelbase? I'm Working on mounting my new brazed tube frame and hilux hard body. Ideally the front and rear axles need shifting back about 7mm to line up with the arches, how would I achieve this? Are there any off the shelf parts I could use? |
09-18-2016, 03:54 PM | #2 |
| Re: Wheelbase Adjustment on the SCX10 II
To maintain proper front steering/suspension geo, the front links would stay the same. In the rear, you would use shorter upper and lower links and move the upper shock mounts forward on the chassis rail to shorten the WB. I believe Adial has the chassis rail pre-drilled for upper shock mount placement for 11.75", 12" & 12.3" WB |
09-18-2016, 04:37 PM | #3 |
Quarry Creeper Join Date: Dec 2015 Location: ossipee
You should be able to use jato rod ends
Wheelbase Adjustment on the SCX10 II - Similar Threads | ||||
Scx10 and wheelbase | slimfire | General Crawlers | 9 | 09-27-2015 07:06 PM |
Will a Vanquish link set meant for a 12.3" wheelbase SCX10 fit a 12" wheelbase? | Derekuda | Newbie General | 1 | 08-10-2015 06:10 AM |
Scx10 wheelbase | breakingstuff | Axial SCX-10 | 4 | 02-07-2014 11:30 AM |
Extending the scx10 wheelbase. | Paul1234 | Axial SCX-10 | 7 | 09-16-2013 10:52 AM |
Axial SCX10 Wheelbase? | jasons36 | Newbie General | 0 | 03-28-2010 08:50 AM |
