01-27-2017, 09:56 PM | #1 |
Quarry Creeper Join Date: Dec 2010 Location: Hanford
| New v2 build help/advice
OK so I'm just about done with building the roller so now I need help/advice. For electronics I started with a new HH 40t crawl master expert I already had and ordered a HH br-xl and CC 10 amp BEC. This will be mostly a trail rig so I'm thinking an 18t pinion on 3s should combo well with the higher turn motor. Thoughts??? I also picked up a savox 0231 servo to try. I've always been a hitec guy, but figured I'd try this for a trail rig. Thoughts again? I do have a new 7954 I can steal from another rig, but hope this will be sufficient running 1.7's. my last and most important advice needed pertains to the battery. My thought was to run 2 1300 3s merv packs in parallel. Would this be better than a higher mAh full size stick pack? I wanna build this one right from the beginning, but a HH servo might find a home here sometime later. |
01-27-2017, 10:01 PM | #2 |
| Re: New v2 build help/advice
I forgot to ask about shocks. I'm thinking gmade xd's. 85mm, 93mm, or setting else? Right now I have the stocks with 35wt AE oil and dual springs. Thanks in advance. |
01-27-2017, 10:23 PM | #3 |
Quarry Creeper Join Date: Dec 2016 Location: FL
I would looks at the Gmade RSD Shocks. Not sure about the rest. I am personally running stock gearing with an HH 2700kv Stubby at the moment and a MMP with CC BEC and Hitec 7950TH. Most likely switch over my HH BLE PRO to it and pick up a standard size 2700kv sooner or later, hear they have a better lower end. Either way your setup sounds good to me, though I use 3s 5000 mah batteries.
01-27-2017, 10:31 PM | #4 |
Thanks, I was looking at the 90mm rsd shocks thinking if I should wait for them to come in stock.
01-27-2017, 10:43 PM | #5 |
RCC Addict Join Date: Sep 2014 Location: Alberta
| Re: New v2 build help/advice |
New v2 build help/advice - Similar Threads | ||||
Need help/advice on first build | MasterDionaea | Axial SCX-10 | 4 | 05-26-2014 07:46 PM |
build advice | profluxer4life | Axial XR10 | 12 | 11-27-2012 09:05 AM |
first build ....need advice | YelloTJ | 2.2 Scale Rigs | 61 | 02-04-2011 09:10 AM |
Build Advice | pigeonfarmboy | Tamiya Txt-1 and Juggernaut | 13 | 02-26-2006 01:54 AM |
