05-03-2019, 06:03 AM | #61 |
| Re: Best shocks? What to choose |
05-03-2019, 01:26 PM | #62 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
I just ordered a set of Dravtech's with medium springs for my modded Axial RTR 69 Blazer. Without knowing exactly which spring rate would work best, or which weight of oil to run I guess I'll have to experiment a bit.
05-04-2019, 02:23 AM | #63 |
Pebble Pounder Join Date: Feb 2012 Location: UK
| Re: Best shocks? What to choose It can't be. The hardest spring is rated 0.61. If it was N/mm, than, you'd need only 6g of weight to make it deflect 1cm. For a 3kg truck, that's ~750g per wheel and not taking into account the motion ratio of the suspension, that'd be more ~4 meters of spring deflection! It does look more like kg/cm or even lb/in, although if that's the case, then it appears to be still quite soft. I calculated that the stock springs that came with my G2 are ~1.4kg/cm. Does anyone know anything about it? |
05-04-2019, 06:06 PM | #64 | |
| Re: Best shocks? What to choose Quote:
Axial and most manufacturers rate their springs in lbs/in. The range of Axial single rate springs for 90 mm shocks is .70 - 3.03 lbs/in. If you convert Traxxas springs from N/mm to lbs/in, you get a range of 1.25 -3.48 lbs/in, which falls in line with the offerings from Axial. | |
05-07-2019, 05:20 AM | #65 |
Thank you, that works! Does anyone knows what springs are compatible with Proline Pro-Spec Scaler 90-95mm shocks? Anyone knows what are the spring rates that comes standard with these shocks? Last edited by stormridersp; 05-07-2019 at 05:40 AM. |
05-07-2019, 12:08 PM | #66 |
Rock Stacker Join Date: Sep 2017 Location: Germany
I run these Prolines Prospecs on my SCX10 II with 2.0 Ibf/in springs, obviously the weakest available from PL. https://www.prolineracing.com/perfor...hocks-rear.asp Series are yellow springs, wich are part of this kit too: https://www.prolineracing.com/perfor...rings-rear.asp Gesendet von meinem SM-G955F mit Tapatalk |
05-08-2019, 04:44 AM | #67 |
Newbie Join Date: Apr 2019 Location: PORT SAINT LUCIE
How long should a set of shocks last?
05-10-2019, 03:25 AM | #68 |
Newbie Join Date: May 2019 Location: Sweden
I'm gonna buy the gmade rsd piggyback for my scx10II kit after icon shocks keeps failing for me. Any thoughts? Should I go with the 90 or 100mm, read about people using gmades 100mm with good results but I don't wan't my car looking like a monstertruck. |
05-11-2019, 02:41 PM | #69 |
Pebble Pounder Join Date: Jan 2018 Location: Northeast Iowa
05-11-2019, 09:50 PM | #70 |
Rock Stacker Join Date: Oct 2016 Location: NYC
I have the incision shocks on two rigs. Getting the spring tuning kit to really dial it in helps a lot. No leaks on mine. Never had the prominent shocks, but have heard great things about them. Sent from my iPhone using Tapatalk |
05-12-2019, 06:31 AM | #71 |
05-12-2019, 10:15 AM | #72 | |
What version of the Pro Specs? Short course? Scaler? Cheers | |
05-12-2019, 10:40 AM | #73 |
In run both front and rear the Pro Spec Short Course for rear without limiters. Gesendet von meinem SM-G955F mit Tapatalk |
05-12-2019, 03:41 PM | #74 |
Quarry Creeper Join Date: Jun 2015 Location: Lancaster, NY
My biggest issue with shocks is that most of the ones I’ve tried have leaked at some point. With the exception of gmades and the ssd scalers I have. My second issue is cost. It sucks when a set of shocks costs you $100 and they end up leaking. One of the things I’ve noticed about the hpi venture guys is none of them complain about the shocks. So I ordered 2 sets of stock venture shocks on eBay which were a grand total of $48 for 8 shocks. We shall see how they work but for $24 a set I don’t think they were a bad purchase.
05-13-2019, 12:06 PM | #75 | |
Can you measure the springs? Lenght, Inner Diameter and Outer Diameter? My Pro Spec Scalers should be arriving soon, I'd like to compare with stock springs. Cheers | |
05-13-2019, 10:02 PM | #76 |
The Prospec shocks #6308-22 have: Innderdiameter: 16.5 mm, outerdiameter 18.8 mm length: 74 mm Gesendet von meinem SM-G955F mit Tapatalk |
05-16-2019, 10:08 AM | #77 |
05-19-2019, 12:41 AM | #78 |
Rock Stacker Join Date: Apr 2009 Location: PNW
FYI, Axial springs for 90mm shocks (their 12.5 x 60mm springs) fit well enough on TRX-4 GTS shocks. I just made the swap to the Traxxas shocks and I'm reusing my Axial springs as I like the spring setup I have now. |
05-19-2019, 01:53 AM | #79 |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
I’ve been using the ssd scale shocks for a few months now and they’ve been great. I’ve been able to use traxxas springs for tuning. No leaks and still smooth.
05-21-2019, 12:30 PM | #80 |
Rock Stacker Join Date: Apr 2019 Location: Reno, NV
Traxxas GPS shocks on all three of my crawlers.
Best shocks? What to choose - Similar Threads | ||||
Help me choose a set of shocks | Bucktallica | Axial AX-10 Scorpion | 12 | 03-17-2010 12:30 AM |
