11-30-2018, 06:09 PM | #21 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: SDD are you holding out on us?
I like them. A good looking portal box add on that isn't bigger than it needs to be. Thank you SSD
12-04-2018, 11:45 AM | #22 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
Ditchrat have you even TRIED green eggs and ham?!? yes the nylon is lighter than metal. there are ways to get weight down low to make up the difference. i have their yeti axle and i swear its BOMB PROOF. i mean... a YETI. if its lasted on that over a year, i think it will be fine on a crawler. i stand by SSD their products are amazing. and im not a portal guy but i certainly wouldn't come in here to knock them. |
12-04-2018, 01:21 PM | #23 | |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
| Re: SDD are you holding out on us? Quote:
12-04-2018, 01:30 PM | #24 | |
RCC Addict Join Date: Nov 2014 Location: Nowhere
Not my pic but example: | |
12-04-2018, 01:33 PM | #25 |
| Re: SDD are you holding out on us? I can definitely see it being as issue with the added leverage of portals.
12-04-2018, 01:40 PM | #26 |
RCC Addict Join Date: Oct 2014 Location: UK
| Re: SDD are you holding out on us? |
12-04-2018, 01:48 PM | #27 | |
When do you anticipate releasing compatible front housings that will work with the portal knuckles? Also, will you be offering different levels of completion for them (axle housing w/ knuckles and add your own gears, axle shafts and bearings, fully complete slap-it-on-and-go, etc)? I'm very interested in these as I was going to upgrade my kit to the Pro44 housings anyways, might as well go all in with portals! | |
12-04-2018, 02:03 PM | #28 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
I wish the portal housings was made in steel ( not brass ) maybe stainless. I would have to completely ditch my old Axles as if i used them i will get weight up high ( er ) so what i have added to my current axles i cant really use. Then again i wouldn't mind all that much aside for the money aspect which i have to look at hard as a retired guy on a meager pension. we will see i am stuffing my piggy bank as hard as i can as i have to upgrade the GFX card in my computer next year, maybe i can save enough to get a set of new sweet SSD portal axles. |
12-05-2018, 04:04 AM | #29 | |
The packing will be the same as the portal rear axle so you need your own gears, locker and bearings. The rest is included as the shafts are portal specific. So to be clear, new nylon tubes (without tiny splines) and new aluminum C hubs to match the new style of fitting. We will go forward with this new reliable fitting with new products next year also. Last edited by SSD; 12-05-2018 at 04:08 AM. | |
12-05-2018, 04:07 AM | #30 | |
Machined steel is not viable, it would cost too much. So Brass weights (that are in progress now) is the easiest and most cost effective way to add the weight. | |
12-05-2018, 04:29 AM | #31 |
Quarry Creeper Join Date: Nov 2016 Location: Switzerland
Very nice portals. What about retro fitting rear portals to a pro44? Any chance or do I have to buy the complete rear portal axle? |
12-05-2018, 04:56 AM | #32 | |
The only difference between the rear portal axle and a retro fit kit would be removing the Pro44 center section from the packing. So it is something we will do in a few months. It wont reduce the cost by much it would just be a few plastic parts and less screws. So it's not worth waiting for really. Last edited by SSD; 12-05-2018 at 05:01 AM. | |
12-05-2018, 12:06 PM | #33 |
Yeah. I don't think i need all as much weight as i have now with brass parts front and rear, i am mostly worried that i cant get the rear axle heavy enough ( have your ALU transmission that shift some weight forward ) I feel my car perform really well now in regard to F/R weight balance, but i am sure i could loose some weight in both ends and still have the same performance. maybe front and rear faux brake disks in brass will be enough, after all the portals do add a little weight too with the hardware inside them. |
12-09-2018, 07:33 AM | #34 | |
Rock Crawler Join Date: May 2013 Location: Uniontown
Sent from my SM-G950U using Tapatalk | |
12-09-2018, 09:58 AM | #35 | |
Right because sorcca loves their idiotic, non sensical rules everyone making parts should follow suit? Their are plenty of rule sets out there that allow adding weight if desired so I'm saddened that anyone still follows their bs. | |
12-09-2018, 11:11 AM | #36 |
Sad or not, national meets use their rule set. Sent from my SM-G950U using Tapatalk |
12-09-2018, 11:58 AM | #37 | |
I'm making weights for these first as they are much cheaper for the user. The majority don't compete or follow rules. | |
12-09-2018, 12:12 PM | #38 |
I have the round rear portal box covers on my FC Jeep TRX. Offset the excessive front weight bias nicely. Sent from my SM-G950U using Tapatalk |
12-25-2018, 09:19 AM | #39 |
Quarry Creeper Join Date: Oct 2011 Location: liberty
I just opened my portal axles, my wife gave them to me for Christmas. They look great. Going to be using beef tubes front axle. SORRCA has some crazy thinking to not allow these for comps.
12-25-2018, 01:30 PM | #40 |
Quarry Creeper Join Date: Nov 2006 Location: Lexington Park
SDD are you holding out on us? - Similar Threads | ||||
Link length for SDD diamond axle for 12,3" wheelbase | le varan | Axial SCX-10 | 2 | 02-18-2018 11:06 AM |
How are these holding up? | jsu101 | RC4WD Trail Finder 2 | 11 | 04-26-2012 07:15 PM |
how is your wk holding up? | flip3d | HPI Wheely King | 14 | 06-11-2007 05:31 PM |
