06-07-2011, 10:13 PM | #81 | |||
I wanna be Dave Join Date: Jun 2004 Location: Whales
It totally does, and even with 2.2 tires on the Honcho, it still looks a bit tiny Quote:
My son puts 2-3 batteries through this rig a day and he's finally broken the cage work. It's the two plastic support pieces that attach the stinger to the main chassis. I'm really surprised it's held up as well as it has | |||
06-13-2011, 04:49 PM | #82 |
I mentioned a week or so ago that my servo was getting a little sloppy due to it having a bushing on the output shaft rather than a bearing, so I dug into it and found a bearing tha fit like a glove. 10mm x 5.93mm x 2.94 I am guessing but that's sounds like a 10 x 6 x 3 At anyrate it took all the slop out of the servo and now it runs like a raped ape. |
06-13-2011, 11:50 PM | #83 | |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
06-13-2011, 11:55 PM | #84 |
Rock Crawler Join Date: Feb 2008 Location: CHESAPEAKE, Va
How's the new motor doing?
06-14-2011, 10:01 AM | #85 |
Pebble Pounder Join Date: Dec 2009 Location: Shenandoah Valley
I have asked this question in the electronics section but just thought I would ask you, but have you tried changing any of the setting on the ESC with out the castle link?
06-15-2011, 09:07 AM | #86 |
Quarry Creeper Join Date: Dec 2010 Location: USA
06-16-2011, 01:35 PM | #87 |
06-16-2011, 01:43 PM | #88 |
I'm not sure how you would program the ESC without a Castle Link. There are no program buttons or indicatior lights like you have on a Tekin ESC. |
06-16-2011, 01:44 PM | #89 |
Say hello to my dactylion Join Date: Jun 2004 Location: On the Boat to Whore Island
06-16-2011, 02:05 PM | #90 |
RCC Addict Join Date: Dec 2004 Location: Behind the wheel of an Axial R/C
It is possible, but you need the castle field link. So yes it can be done without a computer but You still need to purchase an additional item. http://www.castlecreations.com/suppo...d_link_car.pdf |
06-16-2011, 02:15 PM | #91 | |
EDIT: Oh hey I remember you showing me that now. | |
06-16-2011, 02:16 PM | #92 |
Well look who it is...NaZ-T. It's been a while. Thanks for the details on the FPU, I totally forgot about that. It's good to see you out and about |
06-16-2011, 02:48 PM | #93 |
I am not trying to be a smart butt or a know it all. My nephew bought a honcho the other day so I set it up for him. After I binded the remote I was thinking I was going to need to caliberate the ESC and I thought I was doing it but it started beeping and doing the flashing like my HH ESC. Thats when I noticed it was in the programming mode. I was able to change the drag break and the reverse modes. So I asked the question on here and written below is what a guy said he was able to do too. This is copied from my thread. Guy from Austraila just hacked the stick program for the AE-2! "I have worked out how to program some features of the AE-2 without using Castle Link. Like the Castle Creation SideWinder ESC, the standard way of getting into the programming mode is as follows. You may want to disconnect your motor from the ESC first to avoid the chance of a runaway. 1. Switch off the ESC 2. Switch on the transmitter and hold full throttle 3. Switch on the ESC 4. Release the throttle AFTER the second series of tones The ESC uses tones to indicate what Options you are currently accessing and its setting. eg. Option 2 setting 3 will be "beep-beep, pause, beep-beep-beep". You accept the setting for the option by engaging full throttle, or you can go to the next setting by engaging full reverse. Once you have configured the last option, the ESC will emit a series of tones and when that is finished the settings are stored. There are 3 Options available and here are the Settings available: Option 1 - LiPo CutOff (I think, please test first) Setting 1 - Off Setting 2 - On Option 2 - Drag Brake Setting 1 - Off Setting 2 to 6 - varying degree Option 3 - Brake/Reverse type Setting 1 - Forward-Brake-Reverse Setting 2 - Forward and Brake only Setting 3 - Forward and immediate reverse For a crawler using LiPo, the setting would be: 1-2 2-6 3-3 Last edited by LostCrawler; 06-16-2011 at 02:53 PM. |
06-16-2011, 02:58 PM | #94 | |
06-16-2011, 03:54 PM | #95 |
Quarry Creeper Join Date: Sep 2006 Location: Orange, CA
06-16-2011, 08:44 PM | #96 |
Quarry Creeper Join Date: Dec 2010 Location: Franklin, Va
and how would YOU know mr. smart pants??!!
06-17-2011, 08:52 AM | #97 |
06-19-2011, 02:03 AM | #98 |
Pebble Pounder Join Date: May 2011 Location: Fort Bliss
Any update on how that motor is doing if you've had time to put it in Kaetwo?
06-21-2011, 07:07 PM | #99 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
People were commenting on when they came out? I just picked mine up from the hobby shop in Hamilton Ohio tonight (tuesday). Just snipped the factory connector off to solder a deans connector on. The hobby shop ordered 10 mine was the only on shipped. They are saying mid july now. The wierd thing is the serial # ???????? Its on the ...... servo. Trucks awsome!
