12-10-2013, 06:47 PM | #201 | ||
| Re: Rear axle short shaft issue? Quote:
12-16-2013, 08:40 AM | #202 |
Newbie Join Date: Nov 2013 Location: Lakeside
Ok, so it's not me. Started putting my kit together last night and ran into the short side rear axle issue. I must have taken that thing apart 8 times thinking I did something wrong Guess I'll give them a call. Edit: Just called them and a replacement is on the way, nice folks! Last edited by tjpatte; 12-16-2013 at 08:53 AM. |
12-19-2013, 10:33 AM | #203 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
Axial told me since it is more than 90 days old to get bent. Sent from my SCH-I545 using Tapatalk |
12-19-2013, 10:35 AM | #204 |
Quarry Creeper Join Date: Dec 2008 Location: Santa Mira
This is very interesting. I'm about to start a kit myself. I will be looking out for this issue.
12-20-2013, 03:57 PM | #205 |
New ones came in the mail today. The shoulder is definitely thinner and i think it will do the trick.
12-20-2013, 04:40 PM | #206 |
Quarry Creeper Join Date: Sep 2013 Location: Norway
New parts from Axial on the way..
12-26-2013, 09:25 AM | #207 |
Rock Crawler Join Date: May 2010 Location: Bedford Ky
Ok guys I've been doing research on this problem as I'm having it. As I'm not having it with stock axles I can't really find a fix. I have the universals in the rear with a clamping locker and am having the same issue as y'all are with the factory short side rear shafts. Best I can tell I'm only clamping on the very end and when using rear steer it's causing the shaft to pull out of my grub screws. After every run I have to reset the axle and torque the screws. Is there a measurement for the tang end that goes into the locker that I can check or do I need to get a new universal. Thanks for every bodies help. Sent from my iPhone in the shop |
04-07-2014, 10:24 PM | #208 |
Newbie Join Date: Feb 2014 Location: Fountain
Just got my kit in the mail today...started putting together as soon as you tighten screws on lockouts bam...binding! Ima twist lockouts 90 degrees and put screws in at 3 n 6 I dont wannt to drill metal and worry about a beveled flange and so on....doesnt last well ill just get vanquish axles haha
04-08-2014, 12:26 AM | #209 | |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
04-08-2014, 08:57 AM | #210 |
I have the correct screws its just the short side as soon as you take the short shaft lockout off it spins freely but when you tightrn short shaft sidelockout it binds again would it be ok to remove the gasket from the gear in the differential? Does that gasket actually do anything? Its not like its a fluid or wet diff...
04-08-2014, 07:09 PM | #211 |
Ah ok, funny how much variance there is in these, my kit worked fine. Not that that helps you, sorry. Removing the gasket might gain you some clearance, just be careful of the gear mesh, it'll probably go out badly when the locker can float between the bearings. Maybe look at taking the lip off the locker end, the lip on the outer end will stop the shaft moving out & the cross pin & hex will keep it from moving in. |
02-12-2015, 11:17 AM | #212 |
Rock Stacker Join Date: Mar 2014 Location: Nothrwest
Well guys... I cannot thank you enough for finding this problem.. I bought a wraith kit a few days back and had been putting it together.. As soon as I assembled the rear axle binding BAD.. So I would tear it back apart.. Couldn't find anything.. Put it back together.. Same problem.. So I was figuring I got a bad gear set.. So I ordered a new axle with gears.. Got them today.. I tore my old shafts out of the other axle.. (Long one was stuck with loc tite had to hacksaw my way into the axle to get it apart..) put the shafts in and All sounded good.. Then I put the lockouts on.. And low and behold BINDING again.. At this point I was ready to throw it out the window.. Then I clicked search.. WOW !!! So here I sit now doing repair work on something that should have never left the factory .. I have one axle completely destroyed over it.. Had to pay more money to get a new axle.. Just to find out I had to drill a little.. Finally all back up and going.. The fix worked and the axle is smooth as butter.. Thanks guys !!!! |
02-12-2015, 01:54 PM | #213 |
Rock Stacker Join Date: Jan 2015 Location: Burlington, ON, Canada
Just bought my kit version last week and have this issue as well. The included short axle has the older (version 1) thick flange. I called Axial and they are gonna send out a new set, unfortunately they are out of stock and will be a couple of weeks before they get them back in. The rep said he hadn't heard of this issue for quite some time, so perhaps I got a kit that was sitting around for quite some time! Thanks to this forum I've at least found out why the gears were grinding bad. Seeing as how I'm getting the newer axle version, I now have to decide what to do to get up and running in the mean time since I won't get the newer part for almost a month. Maybe I'll just grind the flange off the axel so it will fit in the ring gear farther as I don't want to mess with drilling the ring gear since that would screw up the fitting of the revised axel. |
05-12-2016, 01:18 AM | #214 |
Newbie Join Date: May 2015 Location: UK
Hi, I have just got my first axial kit, the wraith spawn. After hearing how axial were supposed tho be the best.... Well like many others, the front axle went together really well. Then the rear axle was just horrible. Like others I stripped it down, swapped parts in and out, wasted a whole evening.... I hope axial / hobby store sort it for me here in the UK.... I will let you know. Cheers for a great thread and excellent resource
05-13-2016, 12:34 AM | #215 |
Quarry Creeper Join Date: May 2012 Location: Italy
Sad this issues is still existing after such a long time... Never managed to get the older version replaced, so I had to lathe / narrow down the flange that is too thick and creates the bending issue.... Funny enough I had it in my honcho as well when upgrading to HD rings and HH spool. Tight tolerances and same binding issue... I read around axial tolerances are not very consistent on the HD rings.... |
05-16-2016, 12:25 PM | #216 |
I called the model shop and they wanted me to return the axle, so I did. The next day I got a call and they have shimmed the ring gear and posted it back. Very quick and efficient service so far, so as soon as I get my hands on the parcel I will update. If they had said that is what was needed though, I could have sorted it without all the posting back and forth..... Also .... off topic slightly but the new three piece drive shafts are far from straight! The male part of all the options in my kit are all banana like to varying degrees.... Chris UpDate New drive shafts arrived very promplty.... much straighter! Thank you Modelsport UK Last edited by Chris914; 05-25-2016 at 11:40 PM. Reason: update |
04-24-2017, 06:46 AM | #217 |
Newbie Join Date: Apr 2017 Location: Nashville
I have this problem on a new Axial Wraith Spawn kit that I bought from a dealer on Ebay last week. I ordered vanquish axels, hopefully that will take care of the problem |
