07-20-2012, 08:33 PM | #161 |
Quarry Creeper Join Date: May 2012 Location: Houston
| Re: Rear axle short shaft issue? |
07-21-2012, 05:09 PM | #162 |
Quarry Creeper Join Date: Sep 2008 Location: NW San Antonio
07-23-2012, 06:57 AM | #163 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
Anyone have pics of the updated shaft? I think mine has the faulty one, but I'm not certain sicne I have nothing to compare it to.
07-23-2012, 11:16 AM | #164 |
07-23-2012, 11:24 AM | #165 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
The flange that seats against the locker is half as thick on the new version of the short shalf. If they are the same, you have the old style. I was told all the new axle shaft kits have the revised short shaft. |
07-23-2012, 12:17 PM | #166 |
| Re: Rear axle short shaft issue? Nope...no pics of the updated short shaft that I've been able to find. I recall someone saying something about the collar being almost thin enough to create a sharp edge, and if that's the case, then I definitley have the old style. Half as thick as the one on the long shaft? That's what I'm asking....what do I have to compare it to? Last edited by Sh0rtBus; 07-23-2012 at 12:23 PM. |
07-23-2012, 12:30 PM | #167 | |
| Re: Rear axle short shaft issue? Quote:
Yes, compare the inner flange on both shafts to each other, short shaft should be half as wide almost knife-edged...if it's the new proper shaft. | |
07-23-2012, 12:32 PM | #168 |
Its thinner allowing the axle to engage into the locker further. And its very noticable, it almost looks weak now, lol
07-23-2012, 12:36 PM | #169 | ||
Edit: Email sent to Axial Service for replacement shaft. Last edited by Sh0rtBus; 07-23-2012 at 02:05 PM. | ||
07-27-2012, 09:21 AM | #170 |
Sent my email off to Axial Monday afternoon and got a reply first thing Tuesday morning that I had rear axle shafts coming. I was for most of the evening, but when I got home about 9:30 last night, these were waiting in a small FedEx package on my door step. Thanks Axial for the Prompt service! And since I know there isn't a pic up yet that shows a comparison between the old shaft and the new one with the updated collar, I figured I'd post one for others to see in the future. These will be going in my Wraith when I get home from work this afternoon. Last edited by Sh0rtBus; 07-27-2012 at 09:24 AM. |
07-27-2012, 12:55 PM | #171 |
Newbie Join Date: May 2012 Location: Lewisville
Looks like I have the same problem, gotta try to find me recipe for the wraith.
07-27-2012, 04:18 PM | #172 |
Newbie Join Date: Feb 2012 Location: ca
So whats the best fix? grind off the lip on the axle or drill the ring gear? I noticed this problem during both my builds and I am getting some wear on my ring gears because of it. Need to fix it tonight and have been leaning towards grinding the axle.
07-29-2012, 04:46 PM | #173 |
Rock Stacker Join Date: Feb 2012 Location: Flinthills
I pulled mine off my RTR, noticed it was the older version. Did not have a problem reinstalling the axle or the lockout. That being said I have burnt up the stock motor and the Axial 27t in it now gets pretty hot. It was only running on a 3300 nimh, crawling and bashing. Should I be getting the newer version of the short shaft?
07-30-2012, 06:54 AM | #174 | ||
And just FYI....it didn't fix my problem. I managed to smoke an Integy 35T V11 Pro Friday running some light trails. Granted, I was at full throttle a lot of the time, but I've got something binding somewhere, so I need to do a full teardown of my axles and trans to find out what's going on. | ||
07-30-2012, 08:01 AM | #175 |
Thanks shOrtbus. I'll send an email to Axial and see what happens.
07-30-2012, 08:07 AM | #176 |
07-30-2012, 09:45 AM | #177 | |
EDIT: But it solved my issue. Last edited by Natedog; 07-30-2012 at 10:22 AM. | |
07-30-2012, 10:02 AM | #178 |
07-30-2012, 10:08 AM | #179 |
RCC Addict Join Date: Mar 2010 Location: Yelm
I haven't purchased any of my axles "new", so no sales receipt here. I imagine axial would just tell me to pound sand then? I chose to remove the lip off of the axle shaft. I have done it to three axles now, and it made a world of a difference. I wouldn't recommend modifying anything else to get it to work, when it is the shaft that is the problem. |
07-30-2012, 10:22 AM | #180 |
