12-27-2011, 02:33 PM | #81 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
| Re: stock speed ?
I say E you say bay E BAY E BAY! |
12-27-2011, 04:41 PM | #82 | |
Rock Crawler Join Date: Jan 2011 Location: Groningen, The Netherlands
| Re: stock speed ? Quote:
If You're not in millimetric precise crawling, cheap sensorless will do just fine. I have a hobbywing 8t in my Kyosho ultima DB, and that gets up to 65km/h until I run out of parkinglot, that is. Didn't dare to try 11.1v. £85.- or thereabout, even cheaper on flea-bay. | |
12-27-2011, 05:05 PM | #83 |
| Re: stock speed ?
I definitely need 35kmh, I need a ESC that doesn't have a fan as well. I intend on waterproofing it. There's just too much to know, and mistakes prove costly. Don't get me wrong I do like the wraith its just getting right under my skin.
12-28-2011, 07:42 AM | #84 | |
Have You thought about a cheap, brushed modified in the 19 to 15 turn range? Single-wind for raw, axle twisting accelleration, and double-wind for smooth power delivery, and controllable mid-range. Especially with a 17 t single mod 35kp/h is easy, and it will still crawl admirably. Any ballbearing equipped modified motor is better than a Titan as far as performance goes. With the surge in brushless, brushed motors are getting cheaper and cheaper. Conrad dot com has a plethora of cheap, brushed modified 540-type motors. The only thing is that brushed mods need a bit of maintenance every now&then. Worn-out brushes need replacement, comms need to be cut... Etc. Etc. ( the exact reason I got fed-up with expensive -on the long run- brushed motors. BL seems expensive at first, until one realized that the only parts that wear, are the ball-bearings, and they are just €12.- to replace once a season.) plus the power..The Powerrrr!! But, at least for some experimenting , brushed mods are a relatively cheap option. And they don't mind getting wet much. The Traxxas ESC will also run with a 15t mod on stock gearing (20/80). Plenty fast. If You decide to plonk-down the money for a brushless, do not go above 10 turns (VXL is a 10 turn 3500kv, so You know) and see if You got the funds for a sensored set. I realized that an 6.5 to 8.5 BL was exactly in the ball-park for my lust for speed, allthewhile not forgetting about heavy off-roading. ( the 6.5 is a bit of over kill though..) Last edited by Jay-Em; 12-28-2011 at 07:54 AM. | |
02-09-2012, 02:25 PM | #85 |
| Re: stock speed ?
A couple of Titan twelve turns later I've just tried a Titan twenty one reverse rotation, ran on 3s, 23/80. Absolute pants. Fair bit of torque but slower than stock. Probably get a hobbywing 10 t next and try to waterproof it.
02-09-2012, 02:55 PM | #86 |
| Re: stock speed ? What is "pants?" How much slower than stock?
02-09-2012, 03:32 PM | #87 |
| Re: stock speed ?
Only a couple mph, I want a rock racer, jumps and mud bogging. As it stands now if I drive full throttle off a small ledge, the motor doesn't even have enough power to let all four wheels land at once. Its always nose diving. I'm gonna get a hobbywing brushless and try and waterproof it. I've been looking at the 13.5t, I don't want ballistic, just not stock speed. I would recommend the Titan 21 if you were happy with 12ish mph. Its very torquey . Pants is English for underwear, a figure of speech for crap. Or garbage whatever that means lol Last edited by crazee horse; 02-09-2012 at 03:35 PM. |
02-09-2012, 03:40 PM | #88 |
| Re: stock speed ?
OK thanks, got it now. |
