02-09-2012, 08:43 AM | #21 | |
| Re: CMS/Panhard benefits? Quote:
I would rather have the servo on the chassis than on the axle, therefore more scale. Sorry for the confusion. The Wraith is not my comp rig so I can deal with the slight forced articulation from the CMS. It was also easy to make the adjustments I needed for my ride height to eliminate all bumpsteer. | |
02-09-2012, 08:46 AM | #22 |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
To eliminate bump steer in a 1:1 the panhard bar and trag link need to be the same length and be running at the same angle.
02-09-2012, 09:04 AM | #23 |
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
Now mind you I have not had my Wraith with the CMS/Panhard on a trail, but cycling the suspension in poser mode I have no contact of the draglink or panhard bar with the axle, draglink or frame. I'd say you just need to do some adjusting. Follow Harley's method, loosen EVERY part up cycle/adjust then tighten. |
02-09-2012, 09:31 AM | #24 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
Thread: CMS/Panhard benefits? I would want any Newbie to feel that buying this system will help there rig perform better. | |
02-09-2012, 09:57 AM | #25 |
Rock Stacker Join Date: Jan 2012 Location: Birmingham
Would the new Dinky RC 4-Link mounts allow you to run your 4-link setup with a CMS and panhard? Would there still be the binding/bumpsteer issue regardless?
02-09-2012, 10:00 AM | #26 |
The setup has no bump steer when setup correctly. There are two holes on the axle mount side. The top one is for VP knuckles (high steer) and the lower is for stock geometry knuckles. The reason is for keeping the drag link and panhard parallel. Lowering the Wraith to a better ride height also makes everything more efficient in regards to steering power transfer. When I installed the kit on my rig I actually didn't noticed hardly any change in performance. If you think a servo on the axle looks fine then this kit just isn't for you. But if you want any scale looks this should be the first mod you do! The change from a 4-link to 3-link with panhard is just to keep the rig performing the best it can. You are still a dumbass... Read the replies. They have said 5 times that the benefit is scale appearance not performance. |
02-09-2012, 10:01 AM | #27 |
| Re: CMS/Panhard benefits? |
02-09-2012, 10:07 AM | #28 | |
How does it appear more scale? If I am a dumb ass you are a suck ass who is alway looking for free bee's I guess because you have a red star you now know . Get over your self Again there is no benefit in wasting people money on this crap. I DID THINK YOU WHERE BETTER THAN THAT. Last edited by sally1800; 02-09-2012 at 10:12 AM. | |
02-09-2012, 10:14 AM | #29 |
| Are you kidding me? It is more scale appearing by hiding the huge servo. Thus the reason it has been so popular.
02-09-2012, 10:24 AM | #30 |
02-09-2012, 10:29 AM | #31 |
02-09-2012, 10:45 AM | #32 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
Correct me if I'm wrong but the reason you need to take a link off is because of the double triangulation of the 4 links. You could if your dead set on running 4 links do a lot of mods and make the uppers or lowers run parallel and then use the pan hard to keep the axle strait. I'd rather just take one link off myself call me crazy |
02-09-2012, 10:48 AM | #33 | |
02-09-2012, 11:08 AM | #34 |
02-09-2012, 11:12 AM | #35 |
02-09-2012, 11:23 AM | #36 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
Nice CJ, always wanted to make it over to Farmington NM for some 1:1 wheeling. Ever go to Moab? I'll be there over Memorial Weekend again this year. |
02-09-2012, 11:41 AM | #37 | |
| Re: CMS/Panhard benefits? Yes it is Quote:
You'd love Farmington I have been, but not in this rig no. | |
02-09-2012, 11:45 AM | #38 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
Is this real life ? |
02-09-2012, 11:49 AM | #39 |
02-09-2012, 11:50 AM | #40 |
| Re: CMS/Panhard benefits? Then why promote Panhard benefits? Yes the servo on the axle doesn't look great or scale. But the jacked up Drag Link it uses kills the steering throw. I am still stuck on how this Panhard looks more scale if that is what there trying to feed but posting a picture of a 1:1 with 4 link. People waste a lot of hard earn money on this stuff. If it work better so be it. So true. But the $40-$60 that people are wasting is. Last edited by sally1800; 02-09-2012 at 11:56 AM. |
CMS/Panhard benefits? - Similar Threads | ||||
vp cms/panhard | ax10tn | Axial Wraith | 22 | 02-07-2012 05:38 AM |
Why Does Level3 CMS not have a Panhard?! | alexchen86 | Axial SCX-10 | 3 | 01-11-2012 11:55 AM |
VP CMS and panhard on a lowered Wraith?? | Ernie W | Axial Wraith | 5 | 12-28-2011 04:46 PM |
A quick video review of the Vanquish CMS & Panhard | Harley | Axial Wraith | 6 | 11-10-2011 09:56 PM |
