02-09-2012, 11:59 AM | #41 | |
| Re: CMS/Panhard benefits? Quote:
Steering throw isn't affected. I running universals and I have full throw left/right with the CMS and panhard. This stays true through the cycle of the suspension. I completely agree that most 1:1's run a 4 link suspension. However, some types of 4 link suspensions still require a panhard to locate the axle (stock jeep, non triangulated). Unless you are running hydraulic steering a triangulated 4 link will only bind the suspension if you try to run it with a panhard parallel to the drag link to eliminate bump steer. So with the current options available for the Wraith we have 2 choices. CMS 3-link with a panhard to remove the servo from the axle. or... Stock Triangulated 4-link with the servo on the axle. Both with their own pro's and con's. | |
02-09-2012, 12:00 PM | #42 |
| Re: CMS/Panhard benefits? |
02-09-2012, 12:03 PM | #43 |
02-09-2012, 12:11 PM | #44 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
I have never been a fan of the three link. Maybe I just got use to this so called bump steer. It seemed that you where throwing a buy it commercial to the public. Maybe since you get it free. But again thanks for making it very clear that this will not help with performance. Last edited by sally1800; 02-09-2012 at 12:14 PM. | |
02-09-2012, 12:14 PM | #45 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
This seems to have gotten way off from the original questions, as I understand it. Is there a benefit to running the kit and why do I still have bump steer. My 2 cents. The pan hard and steering link need to be the same length, same angle when viewed from the front and top. The angle when viewed from the front cannot be too steep. If you get this right there is very little bump steer. as far as benefits, you can hide the servo! Of course you can hide the servo without doing this. It just means you live with bump steer. Wes |
02-09-2012, 12:17 PM | #46 | |
Yes If you turn your shock mount over or run shorter shock you should be fine. | |
02-09-2012, 12:18 PM | #47 | ||
Also you may want to re-think the bent drag link vs. straight drag link. If they are connecting 2 points in the same exact locations they are going to do the same exact thing. Make sense? | ||
02-09-2012, 12:23 PM | #48 | |
Yes I would have to try. I think that angle with the stock shock seams really tough to work with. When I tried rear steer on to the Pirate 4x4 until I lowered the servo it was weak. It came down to the angle it was pushing or pulling @ | |
02-09-2012, 12:24 PM | #49 | |
The reason they did that was because of trying to keep the rod ends within their range of motion. This is due to their design. Thats not needed on the VP kit. Both kits do the same thing. | |
02-09-2012, 12:34 PM | #50 | ||
RCC Addict Join Date: Jul 2009 Location: Farmington, NM
| Re: CMS/Panhard benefits? Apparently... Quote:
Jacked up Draglink? I get full throw out of mine, I said this before, I'll say it again, you need to tune your setup Wasting $50? First off it's more than $50 for the whole setup. 2nd...Really? Common we play with toy cars, honestly...Some of us have thousands of $$$ tied up in single vehicles...We do this because we LOVE to do it. We do this to mimic 1:1's. There is no such thing as wasting money on something you love to get it the way you want whether or not it's functional. I said it before, I'll say it again. If you don't like the setup, don't want to spend the $$ on it, then DON'T, it's that simple | ||
02-09-2012, 12:39 PM | #51 |
I re-read your comment on asking if I was 4 link. You said my rig, not my wraith. So just to clarify my 1:1 is 4 link. My Wraith is 3-Link w/ VP CMS and Panhard.
02-09-2012, 12:44 PM | #52 |
Rock Crawler Join Date: Apr 2008 Location: Boise, Idaho
I have had a hard time getting full throw, out of this rig on the front. The rear steer, three linked, panhard, chassis mounted servo has always worked perfect. It's close to being perfect. I haven't worried about it too much, having 4 wheel steering. On my Wraith with servo on the axle, seems to work a little better. Sent from my iPhone using Tapatalk |
02-09-2012, 12:48 PM | #53 |
RCC Addict Join Date: Oct 2008 Location: Alpine,CA
02-09-2012, 12:52 PM | #54 |
02-09-2012, 12:57 PM | #55 |
Pebble Pounder Join Date: Sep 2011 Location: USA
I have a question why not use the CMS with no panhard and 4 link? Sent from my iPhone using Tapatalk |
02-09-2012, 12:58 PM | #56 |
02-09-2012, 01:01 PM | #57 |
02-09-2012, 01:02 PM | #58 |
02-09-2012, 01:30 PM | #59 |
I might try a VP mount on the front. Does anyone know if it will fit on a RC4WD housing? I think the problem I'm having is my three link being short and steep angle, can't get the steering link a the same angle. ? Ideas?
02-09-2012, 01:51 PM | #60 |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
CMS/Panhard benefits? - Similar Threads | ||||
vp cms/panhard | ax10tn | Axial Wraith | 22 | 02-07-2012 05:38 AM |
Why Does Level3 CMS not have a Panhard?! | alexchen86 | Axial SCX-10 | 3 | 01-11-2012 11:55 AM |
VP CMS and panhard on a lowered Wraith?? | Ernie W | Axial Wraith | 5 | 12-28-2011 04:46 PM |
A quick video review of the Vanquish CMS & Panhard | Harley | Axial Wraith | 6 | 11-10-2011 09:56 PM |
