02-09-2012, 02:11 PM | #61 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
| Re: CMS/Panhard benefits?
WOW this is getting ridiculous. Scale = realistic looks. Removing the servo from the axle gives a more scale look period. Saydee take a look at custom front linked suspensions that DO NOT have full hydro chances are it'll be a 3 link with a panhard. Oil pan clearence is a common issue when building a linked suspension, so people run a 3 link. Anyway, to answer Sloppy I'm using ax10 axles cause I have them and I don't think the stock Wraith looks very scale in stock form especially when running some 1.9s. It's just my opinion so no need to start a debate. I don't care what people think about my plans. All I'd really like to know is if the VP CMS mount will allow me to slide it back on the chassis before I buy it. I'm planning on running a 12-12.5" wheelbase not the 13+" or what ever it is. I'm only going to the buy the servo mount and I'll make the panhard mount myself. Brandon can you chime in on this for me please? |
02-09-2012, 02:25 PM | #62 |
Pebble Pounder Join Date: Sep 2011 Location: USA
I also would like to know if you can slide the servo back so you can shorten the front wheel base. I'm thinking it would take a lot of work with custom mount. Sent from my iPhone using Tapatalk |
02-09-2012, 03:17 PM | #63 | |
| Re: CMS/Panhard benefits? Quote:
02-09-2012, 03:23 PM | #64 |
Let's get some real tech in this thread, I.E. How do I make it so that I don't see posts by saydee anymore??
02-09-2012, 03:24 PM | #65 |
| Re: CMS/Panhard benefits? |
02-09-2012, 03:26 PM | #66 |
Quarry Creeper Join Date: Nov 2011 Location: San Diego
Guess I should have just kept my mouth shut. LOL... |
02-09-2012, 03:48 PM | #67 | |
I wanna be Dave Join Date: Dec 2008 Location: ?
Sorry guys I just got stuck on scale appearance over performance. It is now very clear it looks cool but can hurt your steering. As does a Hand brother kit. | |
02-09-2012, 03:55 PM | #68 |
02-09-2012, 05:37 PM | #69 |
02-09-2012, 07:55 PM | #70 |
RCC Addict Join Date: Nov 2009 Location: cleveland,Tn
thought i might try to help brandon out here is a pic of mine not sure if this will help out to me i think you would be able to adjust it back and forth to adjust it to where you need it as long as your rod end doesnt get in a bind. |
02-09-2012, 07:56 PM | #71 |
I've never had any downsides to a properly setup 3 link w/panhard CMS configuration. I love the way they look and performance is fine in my experiences.
02-09-2012, 09:40 PM | #72 |
02-09-2012, 11:05 PM | #73 | |
Pebble Pounder Join Date: Mar 2011 Location: Aurora, CO
I just checked the clearance on mine. You can NOT move it any further back due to the servo itself hitting the bumper brace/shock mount/cage mount "block" along with the factory located radio box. It can move forward, but no more than maybe 1/4" due to the servo horn hitting the back end of the bumper. I just had a thought. It *may* be possible to reverse the servo in the mounting flange to have the servo horn facing the cab of the truck. It probably won't work, but just a thought. Marcus | |
11-08-2012, 04:42 PM | #74 |
Newbie Join Date: Oct 2012 Location: Tucson
My question is if you run a vp linkage and steering upgrade, can you just use the servo mount under the chassis and still have a 4 link system.
11-08-2012, 05:02 PM | #75 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
So I got the VP CMS in a set of VP parts I bought used. I have not yet been able to get the panhard setup. 4 link with CMS has lots o' chassis roll & bumpsteer for sure. My question is: When I get the panhard set & go 3 link can I keep the panhard bar from hitting the axle 1st @ full compression? It looks like the panhard bar will hit the axle brace before my shocks bottom out @ this point. If it will limit my front suspension travel I can save some $ & possibly get rid of the CMS & go axle mount. |
11-08-2012, 05:07 PM | #76 | |
You could move it back with a "shorter" servo. | |
11-08-2012, 05:11 PM | #77 |
CMS/Panhard benefits? - Similar Threads | ||||
vp cms/panhard | ax10tn | Axial Wraith | 22 | 02-07-2012 05:38 AM |
Why Does Level3 CMS not have a Panhard?! | alexchen86 | Axial SCX-10 | 3 | 01-11-2012 11:55 AM |
VP CMS and panhard on a lowered Wraith?? | Ernie W | Axial Wraith | 5 | 12-28-2011 04:46 PM |
A quick video review of the Vanquish CMS & Panhard | Harley | Axial Wraith | 6 | 11-10-2011 09:56 PM |
