03-11-2012, 09:13 PM | #41 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
| Re: Too much articulation wtf?!!?!?
IMO the Wraith doesn't need any more articulation. I have more than a tire height with the stock shocks angled as far as they can. The damn thing is so top heavy, I want it lower.
03-11-2012, 09:24 PM | #42 | |
Rock Crawler Join Date: Oct 2011 Location: Canada
| Re: Too much articulation wtf?!!?!? Quote:
Everyody seems so harsh here. If you don't have any helpful information for him stop padding your post stats. If you think a thread is ridiculous just ignore it, someone else will try to help him instead. What are discussion forums for if not to discuss? it's a strange "community" dynamic on this board. With every post i make i feel like i am walking on eggshells, reading it five times, then waiting for the flaming to begin. I have always stuck to the one tire height articulation and had great results. Start there, and mod to your liking. ...and I am sure I will get torn apart for this post as well | |
03-11-2012, 10:01 PM | #43 |
Quarry Creeper Join Date: Jul 2011 Location: Seattle
| Re: Too much articulation wtf?!!?!? Everyone uses their rig for different driving types, the stock flex limits my vehicle badly where i drive it, but yours is suitable for your needs. I often wonder what other Crawler rigs people have had other than Wraiths when they say it has enough out of the box. I have had many crawlers, and the Wraith simply could not keep up with any of them. But if you are using it as a "Rock Racer" as it was intended to be, it is probably fine, but as a true "Crawler", mine was borderline useless out of the box, with the shocks laid back. It was embarrassing while trying to follow friends with more crawler based rigs.
03-11-2012, 10:20 PM | #44 |
Rock Stacker Join Date: Feb 2012 Location: Auburn
You know what they say about guys with big articulation...
03-11-2012, 10:26 PM | #45 |
Rock Stacker Join Date: Dec 2011 Location: calverton
Long shocks ^
03-11-2012, 10:28 PM | #46 |
Always getting stuck in "holes" they can't get out of...
03-11-2012, 10:35 PM | #47 |
Quarry Creeper Join Date: Dec 2007 Location: At the Gates
| Re: Too much articulation wtf?!!?!? |
03-11-2012, 11:00 PM | #48 |
Newbie Join Date: Feb 2012 Location: Sacramento
Well at least I sure as shit learned sumthin'! Thanks guys, without this thread I would not have understood the reasoning behind people using limiter straps and bumpstops on their rigs (1:1 and scaler) and that's honest truth there!
03-12-2012, 02:16 AM | #49 |
| Re: Too much articulation wtf?!!?!? Limiting straps/bump stops are apparently not used as you think they are on 1:1 going by what you just said. It is constantly shocking to me how many people in the Wraith forum talk about suspension design with such a serious position made on assumptions. Especially people that defend using the stock suspension in crawling situations...
03-12-2012, 08:33 AM | #50 |
Quarry Creeper Join Date: Feb 2008 Location: Montreal, Canada
a lot of travel might help you in some situations, but most of the time, you will need less travel and more traction and less body roll, etc if you want 90 degrees go for it. and the best thing, go out with someone that has the same tires with less travel, then you'll see who has the advantage!!! (5 bucks on the limited one hehe) |
03-12-2012, 09:47 AM | #51 | |
Everyone thinks it's easy till they actually have to climb it. Out of 10 Class 3 trucks that started, only 3 finished. I invite you to came out anytime you can make it | |
03-12-2012, 11:33 AM | #52 |
Quarry Creeper Join Date: Feb 2012 Location: SAN DIEGO
I keep hearing this 90* number being tossed around. I don't think the opposition ever stated they thought they needed or wanted 90*. All was asked for was "more" than stock. In fact, even "better" than stock. If you think the stock ride height is ok than you have not driven the Wraith and are forming opinions on assumption. It's way top heavy and turtles constantly. (let me guess) Thats cause I need to learn to drive" right? Can we stop countering the questions about more travel with '90* is useless and you suck for having it', with maybe a discussion about lowering ride height, which seems acceptable to most, and then increasing droop, at least back to a stock level. The 1 tire height rule you all have boners over is much more than a stock wraith Will have left after the droop kit is installed. Seems on my wraith after the droop and link mount flip if I were to then further limit travel, I might as well take the shocks off. Also, if you are a "scale freak" (not you personally Max), Can you please refrain from being bias as to how a real truck would look at act? Lets assume we are trying to build a crawler only use vehicle and the scale factor was being loosely interpreted For fun. |
03-12-2012, 11:50 AM | #53 |
Okay, so I post a legit post explaining that I understand something in a thread full of contest pissing and even I get flamed. Yea this isn't the place for me. Here's the issues at hand: 1) posting a question to just defend your opinion of an amateur assumption is rude and inconsiderate. Post a real question and try to understand the logic. People on here are apparently very knowledgeable in this area. Listen to their reasoning and at least appreciate their input. No one says you have to agree. 2) making a snotty comeback to said first post is fuel for the tire fire. Now it's all flaming and nothing to be gained anymore. 3) limiter straps can/are used for some purposes like holding your suspension together during max articulation, and bumpstops on full comp rigs keep things from going to the other extreme. Yes I understand how shit is used. 4) I definitely feel welcome in this community now, and look forward to watching my post getting deleted and account banned. Good luck. |
03-12-2012, 11:54 AM | #54 | |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: Too much articulation wtf?!!?!? Thank you for the leaving me out Bela LOL And the 90* number goes back to when people thought and wanted the most flex possible! However even looking at the top comp crawlers most of them don't have the flex that people seem to think that they do. Less flex really helps in a rigs predictability which translates into better driveability. Quote:
03-12-2012, 12:27 PM | #55 | |
Quarry Creeper Join Date: Feb 2012 Location: AZ
People need to stop assuming they know what's best for the majority. What works for someone in one place may not work for others in a different place. I learned a lot yesterday driving with other wraiths. It helped me to understand that, yes, despite the naysayers, a decent amount of flex was needed. I also learned that while lowering the wraith to lower the COG does help but it also limits it in that I got high centered a lot where others could simply drive over. Small adjustments helped and now I think I've found the sweet spot, for me, not necessarily for others. Last edited by dunerinaz; 03-12-2012 at 01:24 PM. | |
03-12-2012, 03:04 PM | #56 | |
90 degrees is NOT ENOUGH! | |
03-12-2012, 03:07 PM | #57 |
03-12-2012, 03:17 PM | #58 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
I spent the last year trying to prove that MORE flex Can be better. Designed a suspension useing cantilevers tied together front to rear. Theory was, when one tire lifted, the opposite tire would be forced down gaining traction. It actually worked somewhat, but it was too unpredictable in off-camber situations. I have since switched back to a traditional 4-shock set-up, but, I may persue this again later. The cracks, crevaces and verticle obstacles were not a problem, but get more than 15* off-camber and forget about it. The chassis would unload and flop over kind of like when your knee gives out. Its all good, then BAM, you're on your face. |
03-12-2012, 04:20 PM | #59 | |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
I think everything that needs to be said has already its all preference and driving style the best way to find what you can drive best and what works for your terrain is determined by lots and lots of practice. you can use other people's setups as a baseline but I'm sure you will drive a bit different and will need slight tweaks O.t. I dig trying different things A+ on this idea wonder how it would work if you could cross the shocks (front left and right rear) Quote:
03-12-2012, 05:49 PM | #60 |
[/QUOTE] O.t. I dig trying different things A+ on this idea wonder how it would work if you could cross the shocks (front left and right rear)[/QUOTE] I thought about that, but no real way to criss cross efficiently. I tried to use cantilevers with 4 shocks, but again space was a huge issue. I ended up running kicker shocks to the front levers. This helped, but again... A 2.2 Honcho would still pull lines I could'nt. I hav'nt given up on this, just needed a break. My next try will involve swaybars. I just need to figure out how they will work effectively without limiting articulation |
Too much articulation wtf?!!?!? - Similar Threads | ||||
wtf losi micro with dig and 4ws wtf | richardgarrett56 | Losi Micro-Rock Crawler | 15 | 07-21-2010 04:47 AM |
how much articulation | Losi man | Losi Mini-Rock Crawler | 23 | 11-15-2009 01:54 PM |
Wtf Wtf Wtf Lathe?!?!?! | Nova | Electronics | 2 | 08-19-2005 08:31 PM |
