03-27-2012, 08:53 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: St. Paul
| Wraith steering servo issue
I'm not sure if anyone has mentioned this, but I made a discovery that may be contributing to stripped servos (I'm on number 4). If you have the stock bumper on, and apply some pressure too the front, my servo horn would hit one of those little plastic bits hanging down for d rings. Again mine has a bunch of mods, but thought it was worth mentioning. I cut mine off and so far so good.. Sent from my ADR6400L using Tapatalk Last edited by wheeler chaos; 03-27-2012 at 08:58 PM. |
03-27-2012, 09:04 PM | #2 |
Rock Stacker Join Date: Jan 2012 Location: SK, Canada
| Re: Wraith steering servo issue
What brand/model servo's have you been stripping out?
03-27-2012, 09:28 PM | #3 |
03-27-2012, 10:27 PM | #4 |
Rock Stacker Join Date: Feb 2006 Location: Ringgold
Thats funny, mine doesnt hit. It just barely clears, but it clears. The guy that put the truck together had the rubber tabs on the servo and it kept working loose so I took them off. I havent had any problems yet.
03-28-2012, 03:43 PM | #5 |
There's barely enough room in the stock plate to drill 2 new holes to move the servo back about 1/4" so it clears the crossmember and actually improves the linkage ratio. You gotta flip the servo so the horn clears the diff cover and make a new drag link. A stock AX-10 upper is the perfect length. I've had my servo moved back since it was built so there's never been any sort of binding, but have still managed to strip three 7954SH's, so there's other things at play here. |
03-28-2012, 10:04 PM | #6 |
I can see that their are other issues at play, but I'm fairly certain this contributed too my problems. The front bumper is shimmed out a little (2mm) too clear the servo horn. When the front suspension was compressed ,and I went too turn left, the drag link rod end (attached too the end of the horn) would smack into the drivers side plastic d ring deal. |
03-30-2012, 03:16 AM | #7 |
Rock Stacker Join Date: Mar 2012 Location: Vancouver
Bumper extension.
Wraith steering servo issue - Similar Threads | ||||
Axial Wraith steering linkage issue. | Jew1028 | Axial Wraith | 3 | 02-27-2012 10:12 AM |
Servo winch installed, now causes steering issue | Harry Handcuffs | Electronics | 2 | 12-29-2011 07:16 PM |
New Build - Servo / Steering issue | Slaughter | Axial SCX-10 | 7 | 05-24-2011 06:23 PM |
R/C Bros LCG steering servo mount issue | bryco13 | Team Losi Comp Crawler | 7 | 04-01-2011 10:21 PM |
Servo Issue - Lost Steering | flowingmotion | Axial AX-10 Scorpion | 15 | 01-11-2010 05:47 PM |
