05-10-2012, 07:19 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
| Bevel gear?
What is the difference between these two set? One set doesn't state the gearing and also looks different. Axial HEAVY DUTY BEVEL GEAR SET 36T/14T Axial HEAVY DUTY BEVEL GEAR SET Also what gearing should i run for the front and rear? |
05-10-2012, 07:32 PM | #2 |
| Re: Bevel gear?
The 36T/14T is the overdrive gear set.. faster than stock.. This is for the front.. Turns the front wheels faster and helps with approaching obstacles and with steep climbs, and slightly with turning radius. The 2nd link you posted is simply a hardened steel version of the stock gearset which is really cheap cast metal. Not necessary unless you're running a lot of power IMHO. |
05-10-2012, 07:38 PM | #3 |
| Re: Bevel gear?
So the second set is stronger than the first? What is the gearing for the stock bevels? Also, Would i need to buy the second set for the rear and the first set for the front? |
05-10-2012, 07:41 PM | #4 |
| Re: Bevel gear? |
05-10-2012, 07:47 PM | #5 | |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: Bevel gear? Quote:
Only one overdrive (Ax30401) or underdrive (Ax30402) gear is necessary for a Wraith IMO. The only reason to buy the gear in the second link would be to replace one of the gears you now have in the truck. It's the same gear ratio, but made a bit stronger than stock. | |
05-10-2012, 08:27 PM | #6 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
| Re: Bevel gear?
The 2nd one now comes with the hole in the shaft and is spriral cut just like the 1st. I just got em from rpp.
Bevel gear? - Similar Threads | ||||
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
worm gear vs bevel gear? | fennex | Newbie General | 0 | 11-05-2010 06:57 AM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
Bevel Gear | mrbigg81 | Tamiya TLT Crawlers | 4 | 11-07-2007 12:24 AM |
