08-28-2016, 12:17 PM | #241 |
Quarry Creeper Join Date: Mar 2007 Location: Celina TN.
| Re: What did you do to your Wraith today? |
08-28-2016, 02:14 PM | #242 |
Pebble Pounder Join Date: Aug 2016 Location: Alabama
Added a little towing accessory . Oh, and I orders a bunch of goodies. New tires, beadlocks, G-Made PiggyBack shocks, and some scale accessories like hooks and shackles. Posted via TapaTalk for iPhone6 |
08-28-2016, 05:18 PM | #243 |
Newbie Join Date: Jun 2016 Location: midwest
Went wheeling today stock motor finally went put 35t boost in I like it good wheel speed and more torque crawls around the trails a lot better put servo and bec in with deans ultra plug the other day much better rig now
09-01-2016, 06:40 PM | #244 |
RCC Addict Join Date: Mar 2011 Location: easton
| Re: What did you do to your Wraith today? Not exactly today but it was this week. I brought it back from the dead with many upgrades Sent from my iPhone using Tapatalk |
09-05-2016, 11:40 AM | #245 |
Newbie Join Date: Aug 2016 Location: Keizer
Well I started to build a wraith today! Hope U like!
09-05-2016, 09:56 PM | #246 |
Rock Stacker Join Date: Sep 2010 Location: Detroit Area
Took my brand new Wraith out today within 3 min I blew out my right rear hub, 2 min later the left went out then had a 2 wheel drive truck. Not real impressed so far. Bought my first set of Vanquish stuff, alumni hub set and hubs.
09-06-2016, 07:28 AM | #247 |
| Re: What did you do to your Wraith today? You must have been spanking on it pretty hard. Or either they were out of spec from the factory. I havent had any trouble out of mine yet.
09-09-2016, 06:16 AM | #248 |
Yeah if it's those plastic pin style they suck my wife spun one on her poison spider and she wasn't even running it real hard at all they are getting switched over to hex hubs hopefully next week my friends spawn did the same
09-09-2016, 07:12 AM | #249 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
09-09-2016, 11:28 AM | #250 |
Bought a replacement motor. The factory one is finally dieing on me. Lasted a pretty good while though. I'm broke at the moment so instead of the Tekin 35T & FXR I want to order, I just went with the Axial 27T For $17. lol... hopefully it will last until I can save up for the Tekin.
09-10-2016, 07:34 PM | #251 |
A lot!! Lol. I'll update my thread with pictures. Put in several hours of work today. The factory motor was pretty much done. Don't have the $doe$ for the Tekin I want so I popped in an axial 27T for now. For $17 bucks hopefully it will get me thru a few weeks. Put my pup Shiloh over in the passenger seat. All they had was chocolate labs so I had to krylon her black since she's, well, a black lab after all. Lol Made a tow cable w/ the hooks I bought a few weeks ago. Also made some hood pin safety cables. I removed all of the factory lights. Wasn't using them anyway. Which allowed me to trim the bar they were mounted to. Which in turn now allows the servo to tuck all the way up into the frame and give me a lot more articulation up front. Lastly I moved the NOS bottles down to the bed cover. Still need to get some tube to plumb them up. Posted via TapaTalk for iPhone6 |
09-14-2016, 09:11 PM | #252 |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
I made my own body panels. The rear is from RPP. Not sure how I'm going to do the rear yet. I really don't want a flat cover... Put in the open interior. Put Rx in the rear and ESC up front. Battery is in front as well. Boom Racing linkage. Axial universal front axles. MIP drive shafts. Hot Racing steel transmission gears. Turnigy 1258TG servo. |
09-15-2016, 01:20 PM | #253 |
First time Axial owner, bought my Wraith Poison Spider last month ran it three time now. Prior to running added alumni links. Day 1 inside the house life was good. Day 2 lasted 4 min before I stripped out the rear hubs & replaced with Vanquish all the way around (last week). Day 3 (last night) Lasted 2 min blew out the servo just ordered the Vanquish servo mount, Axial servo horn, and cheap RC Gear Shop servo ($60). Kind of surprised how much this thing is costing me & I have yet to get though a full battery.
09-15-2016, 02:53 PM | #254 | |
Newbie Join Date: Aug 2016 Location: Tracy
| Re: What did you do to your Wraith today? Quote:
09-18-2016, 11:53 AM | #255 |
| Re: What did you do to your Wraith today? Got it running 2 nights ago and ended up swapping out the open rear diff for a locked one, stock iron cross for now. Ran it yesterday for it to end up only being front wheel drive and in minutes one of the screws on the drag link backing out! Upon closer inspection the set screw for the rear drive shaft at the axle wasn't lining up, and replaced the front screw with a longer one and a nylock nut. Went to run it today and one of the screws on the front upper link mount kept backing out, and one of the screws for the knuckles backed out. Also the rear sway bar came apart Sent from my iPhone using Tapatalk |
11-21-2016, 03:45 PM | #256 |
I'm doing a very slow paced rebuild of my first ever RC, a Wraith Spawn. I have two or three other active builds but whenever I find a good deal or a must have new release, I snatch it up and find the best home for it. VP just released some new 5mm universals that are rebuildable and come with 60 degrees of steering right out of the package. As soon as I saw them I ordered up a set and there's no way I can put such a nice new part in an old beat up axle housing so a new VP housing was added to the cart as well. Axial HD ring and pinion, VP diff cover, DMG skid, VP scale clamping hubs, and DLux Fab brass knuckles, truss, and steering links round out the build. This is one beefy axle. Everything spins smooth and feels very solid. Another benefit from this combo was the complete absence of any slop at the wheels. Usually you get some end play on the knuckle and stub shaft unless you shim it out on the inside bearing but this setup is tight as a drum with no binding. Very happy with the results.
11-21-2016, 06:52 PM | #257 |
Newbie Join Date: Jun 2010 Location: Everett
Ordered a SSD Diamond rear axle housing. Gonna wait till next paycheck for the Front. Sent from my iPhone using Tapatalk |
11-22-2016, 10:21 AM | #258 |
Quarry Creeper Join Date: Mar 2015 Location: Castle Rock, Colorado
12-02-2016, 09:35 PM | #259 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
About to get started on some late night Wraith bolt-ons! |
12-03-2016, 07:43 PM | #260 |
Newbie Join Date: Apr 2016 Location: Raleigh
I did this till the rear driveshaft pin fell out... Loctite indeed https://scontent-lga3-1.xx.fbcdn.net...ab&oe=58468D95 |
What did you do to your Wraith today? - Similar Threads | ||||
Got My Wraith Today... | NFA Fabrication | Axial Wraith | 63 | 12-07-2011 07:37 AM |
Got my Wraith today | 98sierra | Axial Wraith | 15 | 06-27-2011 01:58 PM |
