07-16-2012, 08:17 PM | #1 |
Pebble Pounder Join Date: Jul 2011 Location: NorCal
| Wraith problems.. HELP!**
video tells you all that i know.Wraith Problem..PLEASE HELP - YouTube |
07-16-2012, 08:29 PM | #2 |
Rock Crawler Join Date: Dec 2011 Location: thurmont
| Re: Wraith problems.. HELP!**
maybe turning on your truck first is the problem? i always turn on the tx first. sometimes when my ax10 glitches i jusst turn it off, unplug everything and plug it back in and it works. i hope this helps. although i doubt it will
07-16-2012, 08:35 PM | #3 |
Newbie Join Date: Jul 2011 Location: Lewisburg, TN
I would start with checking all my soldering, I had one that kind of acted the same and my positive wire had broken loose on my bec and would lose contact.
07-16-2012, 08:35 PM | #4 |
Rock Crawler Join Date: Apr 2004 Location: here
Bad connection at plug or battery it self? Have you tried different battery? If shaking it will sometimes make it come back sounds like connection. Try alt. battery if it still does it check connector on esc.
07-16-2012, 08:43 PM | #5 |
Newbie Join Date: Jun 2012 Location: Honolulu/Kona
I have two batteries and have a similar problem with just one of the batteries. When it shuts off, try just moving the battery plug/wire around and see if that make things come back on. If it does, you isolated your problem to your battery connection.
07-17-2012, 05:11 AM | #6 |
Rock Crawler Join Date: Oct 2010 Location: Chezzetcook Nova Scotia
Ive seen it many times.. Its the Tamiya connectors.. They are really bad.. Mine was cut off before I even took the truck off the kitchen table. I installed a Traxxas connector to match my other trucks and batteries.. my buddies truck acted just like yours.. Switched out the connector for a Deans,,, Problem solved. No more glitching..
07-19-2012, 06:22 PM | #7 |
Rock Stacker Join Date: May 2012 Location: Bend
Mine was doing similar things and I traced it to a bad positive battery connection to the ESC. Axial was kind enough to send me a new one under warranty.
07-19-2012, 06:56 PM | #8 | |
Newbie Join Date: Apr 2012 Location: under a rock
| Re: Wraith problems.. HELP!** Quote:
07-19-2012, 07:22 PM | #9 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Yup I also had that problem mine was a bad deans plug at the battery connection. Sent from my GT-I9100M using Tapatalk 2 |
07-19-2012, 07:35 PM | #10 |
Its a cold joint somewhere, start with the battery and move your way down the signal chain of electricity to the motor. Although with the lights cycling off, I'm inclined to think its between the battery and esc. Are those wheel weights glued to your tires? |
12-17-2012, 09:42 PM | #11 |
Thanks guys, it was the battery! Helped a lot! |
Wraith problems.. HELP!** - Similar Threads | ||||
Wraith problems | joel810 | Axial Wraith | 3 | 06-12-2012 05:30 AM |
wraith problems.. | demonut | Axial Wraith | 9 | 05-21-2012 05:37 PM |
problems with new wraith | hunterk | Axial Wraith | 9 | 03-01-2012 11:42 AM |
wraith problems | popeye123 | Axial Wraith | 13 | 01-13-2012 01:18 PM |
Wraith Speed Problems!! | WarTrader | Axial Wraith | 12 | 08-29-2011 10:59 AM |
